Microtech Need help! ltx8
Old May 13, 2011 | 11:17 AM
Sammy Built's Avatar
501 WHP Club
FL Need help! ltx8
ok im in the process of installation and my understanding this model computer has the ignitor built in the ecu so I have 91 t2 swap im using and want use the t2 coils so i stripped the ingnitors off them and confused on how to wire them on the coils theself. Do I wire the wire to the postive side of the coil or negiative side?
Old May 13, 2011 | 11:23 AM
RotaryEvolution's Avatar
Sharp Claws
leave the ignitors in the coils, where anywhere did it say to remove them? there is plenty of info about wiring up the coil circuit with a search of this subforum. all 3 ground control circuit wires replace the ones from the factory harness to the stock ECU, the rest of the wiring must remain intact if you want a functioning tachometer and ignition system. the thick black/yellow wire is the power going to the coils, leave this wire alone or rewire it off a ignition switched relay to the battery! for the leading coil the other wire is your trigger circuit off the microtech, i can't recall from memory the color of the ignition wires for the trailing coil pack.
the LT8x has ignition control but it is not a built in ignitor, it is a built in timing trigger which is a low amperage grounding circuit as is most everything on these POS's.
Old May 13, 2011 | 04:24 PM
501 WHP Club
On the ltx8 how do people use 2x set of trailing coils? , so i have to use the stock ignitors cause.... Those dont have a built in ignitor in the ecu right?, then whats the difference on the lt8 and ltx8 then...
Old May 13, 2011 | 05:17 PM
Sharp Claws
i don't recall which series they started having ignition control with but i know that the LT8x and LT8s have ignition control.
i don't know of anyone who runs two trailing coils because the leading is a waste spark setup and you would need to have microtech modify the EMS to run two leading coils versus the stock configuration setup. the LT8x comes defaulted with a single wire to control the stock leading coil pack.
you could alter this without sending it back to microtech but i think you are referring to people who have used other ignition control modules such as MSD, Dynatek, Jacobs, etc to control multiple coils off the ECU signal.
the ECU ignition signal is a simple signal to trigger the spark at a certain time, think of the ignition after the ECU as a seperate entity which still requires an igniter to amplify, divide and control the spark without putting any stress on the ECU.
Old May 13, 2011 | 07:43 PM
bumpstart's Avatar
talking head
LTX 8 is full sequential ECU with inbuilt igniters,, IE it drives FOUR plain jane coils without internal igniters
usually this is 4 x HEC 715,, but can be 4 x FC trailing coils with igniters bypassed
just simply wire 12v to the + side,, and the ECU to the - side of each coil
yellow is for leading coils
orange is for trailing coils
black strip always denotes rotor 2
set the dwell to fixed time base and use around 3.5 ms in screen 31
Old May 13, 2011 | 08:53 PM
Sharp Claws
does it have an external ignition control module? if so i might have mistaken it for the newer models, i could have sworn the X was the most recent which was made to be basically plug n play after soldering the connectors.
Old May 13, 2011 | 09:12 PM
bumpstart's Avatar
talking head
LTX has inbuilt igniters in the ECU case
LTS uses the external igniters x4/x6 box
the L is for laptop version,, M is the older handset only versions
MT/LT ( without suffix ) has only drivers and is intended to use the stock coils with inbuilt ignitiers
( in early MTX,, it will come up with software for "MT coilpack" ( not mtx or ltx ) and is also for 4 coils )
Old May 13, 2011 | 09:27 PM
Sharp Claws
i guess i'm getting alzheimers from sniffing too much hylomar and vaseline. there is also the blue box version which i think was the original LT8s. i could have swore i had the LT8x version but i guess its the s version.
Old May 14, 2011 | 12:00 AM
bumpstart's Avatar
talking head
blue box is digi 1 and 2 and pro
,, digi 2 pro is fuel and ignition and is basically the precursor mt-8 and is designed to run sequential trailing and wastespark leading
( as distinct from the LTX which is 4 individual coil drivers,, not 3 )
Old May 14, 2011 | 02:04 PM
501 WHP Club
FL
So I was right with the ignitor being built in the ecu just wire like you listed and change the configuration on map 31 and thats it!
13BNUT
Microtech
Nov 25, 2007 05:36 PM
Apathy
Microtech
May 30, 2006 01:31 AM
jonjie_13b rew
Microtech
Mar 11, 2006 02:18 AM
savana
Microtech
Sep 19, 2005 10:50 PM
SleeperRx
Microtech
May 17, 2004 05:56 PM
