85 rx7 coolant light
Old May 10, 2011 | 02:14 PM
realelips's Avatar
Newbie
My coolant light comes on and goes off intermittently. reservoir level is where it should be. How do i have to add more to rediator as the manual says? or could it be water pump?
Old May 10, 2011 | 06:09 PM
RLM55's Avatar
Gyratory
Could this be a minor radiator leak? How old is the radiator?
Old May 11, 2011 | 06:19 AM
Kentetsu's Avatar
Are you saying that the water level in the radiator is going down, but the water level in the reservoir is not? If so, then make sure that the hose that joins the two is not loose or leaking. It needs a tight seal in order to siphon water into the radiator as it cools down.
If that hose is good, then replace the radiator cap.
Good luck.
Jutta_J
Mar 25, 2017 11:24 PM
gtcd
30
Aug 19, 2015 02:44 AM
Sharkbait24
Aug 12, 2015 10:36 AM
