Headache-sos
Old Apr 29, 2011 | 01:57 AM
CAPT KIRK's Avatar
Headache-sos
My 90 rx7 has been converted from a automatic to a 5 speed manual transmision,wnen i push the pedal down it wont come back up,and if the car sits for about 3-5 min.it works fine for about 10 min. And does it again....p.t. 2 where is the clutch adjustment located?help me please anybody.
Old Apr 29, 2011 | 10:31 AM
Pele's Avatar
Right near Malloy
I assume you're talking about the clutch pedal.
Your problem sounds like clutch hydraulics. It's either the master or slave cylinder failing, or a bad hose.
Best bet is to replace all three parts. Costs about $100 and takes an hour or so.
Old Apr 29, 2011 | 11:59 AM
Zero10's Avatar
Did you use all new hydraulics? Did you properly bleed the system after installing them? It is either failed master/slave/hose, or air in the system, if they were not all new parts my money is on failed hydraulics.
Old Apr 29, 2011 | 03:29 PM
CAPT KIRK's Avatar
To zero 10, and pele........thanks you guys pointed me in the right direction, its nice to be on the same side. Thanks again bro's
Old Apr 29, 2011 | 03:38 PM
CAPT KIRK's Avatar
Question S.o.s. 411
Where can i buy a slave cyl. In l.a./eagle rock, and whats a good price?
Old Apr 30, 2011 | 01:08 AM
MadScience_7's Avatar
Too old for this
In my experience, finding RX-7 parts at retail stores is nearly impossible. A good first stop for most factory parts is MazdaTrix.
Clutch hydraulics
Old Apr 30, 2011 | 10:29 AM
Aaron Cake's Avatar
Engine, Not Motor
Any auto parts store will have the master, slave and hose. It may take a day for them to arrive, but I've never had an issue buying these parts at any regular auto parts store.
