Microtech Lt8s T04z map?
Old Apr 23, 2011 | 03:01 PM
nuimpykid's Avatar
Lt8s T04z map?
Can anyone help me out with a map? I have a cosmo 13bre large street port, aeromotive a1000 pump, full 3 inch exhaust, fmic, 1000 primary 1600 secondary injectors.
I was dyno tuned on 550 and 1600 with a huge horrible rich spot. I sent my primaries to get bored to 1000 and I am in need of a map. I was running around 16 psi before... Would like to get up to around 18 psi on 93 oct.
Any help is greatly appreciated!
I did search and found a couple t04z maps, but they had different pumps, and was not sure if they would be the best option. Wanted to see if someone had a set up close to this!
Thanks!
Old Apr 24, 2011 | 02:18 PM
nuimpykid's Avatar
50 views and nothing? I will really be needing this later in the week. If anyone has/found something close, or can tell me if they ones I found with different fuel pumps would be close? I guess it would just depend on base fuel pressure right?
Thanks!
Old Apr 24, 2011 | 05:22 PM
tony94s4's Avatar
Corn Fed FD
pm rx72c he is the king of mt maps
Old Apr 24, 2011 | 06:36 PM
drifting in drifting's Avatar
Good luck some ******** pissed him off so he wrote microtech support off.
I would do a search through his posts youll find a 1000 1600 map and it will work
Old Apr 26, 2011 | 04:09 PM
eddierotary's Avatar
back with rotaries
i know, i would like to thanks the f#&*ng a$$hole that **** rx72c off, he help me alot in the past with great results, i haven nothing to complain of him but now i need a map too and i havent heard anything from him latelly.
Old Apr 27, 2011 | 01:35 AM
nuimpykid's Avatar
I found a couple maps to try, I will post up results when its all together.
Old Apr 30, 2011 | 10:08 AM
Aaron Cake's Avatar
Engine, Not Motor
I don't suggest you plug in other people's maps and then run the engine under load unless you enjoy rebuilding engines.
Using other's maps as base maps needs to be done with extreme caution. If you do this, I'd suggest comparing the numbers with your current map to at least see if it safely close.
Old May 4, 2011 | 12:23 AM
nuimpykid's Avatar
I didnt use an entire map, and do not plan on using it for load either. Here is what I used, previously posted by rx72c. It starts and runs, but will not hold an idle. It dies quickly enough that I cant really tell on wideband if im rich or lean at idle. I would guess its flooding out? If anyone has pointers on where to start, it would be appreciated! I still have numbers in the other screens from when it had 550/1600. I am unsure of where to start with those screens.
Idle Map
Screen 1
30" ~ .95
25" ~ .95
20" ~ 1.14
15" ~ 1.44
10" ~ 1.71
05" ~ 1.91
00" ~ 2.14
2-20psi ~ 4.95
Load Map
Screen 3
30" ~ 0.95
25" ~ 0.95
20" ~ 1.13
15" ~ 1.44
10" ~ 1.81
05" ~ 2.24
00" ~ 2.56
2psi ~ 2.2
4psi ~ 3.4
6psi ~ 3.9
8psi ~ 4.6
10psi ~ 5.1
14psi ~ 5.7
16psi ~ 6.0
18psi ~ 6.6
20psi ~ 7.1
RPMwot Map Screen 17
5000 ~ 05
5500 ~ 08
6000 ~ 08
6500 ~ 10
7000 ~ 11
7500 ~ 11
8000 ~ 11
9000 ~ 12
The rest are zero
RPMcrs Screen 18
1000 ~ -12
1500 ~ -11
2000 ~ -12
THe rest are zero
Pump Map
Screen 19
Pump2Start ~ 2000
Pump1Amt ~ 15
Pump1Pulse ~ 04
Pump1Trig ~ 10
Pump1Stop ~ 00
Pump1Adv ~ 05
Pump2Time ~ 10
Pump2Amt ~ 30
Pump2Trig ~ 16
Pump2Stop ~ 00
Pump2Adv ~ 05
PumpDwell ~ 3.00
PumpTimers ~ No
Pump1Sync ~ No
PumpSpare ~ 00
PumpCold ~ 00
Water Map
Screen 20
-25 ~ 0
-17 ~ 70
-9 ~ 60
-01 ~ 50
05 ~ 45
11 ~ 45
18 ~ 42
24 ~ 34
31 ~ 26
38 ~ 24
46 ~ 19
60 ~ 12
68 ~ 06
82 ~ 0
99 ~ 0
124 ~ 0
Air_t Map
Screen 21
-25 ~ 0
-17 ~ 8
-9 ~ 6
-1 ~ 5
5 ~ 4
11 ~ 3
18 ~ 3
24 ~ 0
31 ~ 0
38 ~ 0
46 ~ 0
60 ~ 0
68 ~ 0
82 ~ 0
99 ~ 0
124 ~ 0
Crank Map
Screen 22
-25 ~ 72
-17 ~ 72
-9 ~ 72
-1 ~ 67
5 ~ 62
11 ~ 57
18 ~ 50
24 ~ 41
31 ~ 31
38 ~ 26
46 ~ 20
60 ~ 15
68 ~ 5
82 ~ 0
99 ~ 0
124 ~ 0
t*rpm
Screen 23
Idle ~ 00
1000 ~ 10
1500 ~ 15
2000 ~ 20
2500 ~ 25
3000 ~ 25
3500 ~ 25
4000 ~ 25
4500 ~ 25
5000 ~ 25
5500 ~ 25
6000 ~ 25
6500 ~ 25
7000 ~ 25
8000 ~ 25
9000 ~ 25
t*map Map
Screen 24
Idle ~ 00
25 ~ 05
20 ~ 04
15 ~ 03
10 ~ 02
05 ~ 00
00 ~ 00
2psi ~ 00
4psi ~ 03
6psi ~ 05
8psi ~ -07
10psi ~ -09
14psi ~ -13
16psi ~ -17
18 psi ~ -21
20 psi ~ -25
t*air Screen 25
Correction value Is expressed as number of degrees
you wish to advance or Retard to the Ignition curve
and values Is set at zero.
t*gap
Screen 26
0500 ~ 15
1000 ~ 15
1500 ~ 15
2000 ~ 14
2500 ~ 12
3000 ~ 10
3500 ~ 10
4000 ~ 10
4500 ~ 10
5000 ~ 10
5500 ~ 10
6000 ~ 10
6500 ~ 10
7000 ~ 10
8000 ~ 10
t*Inj Map
Screen 27
0500 ~ 120
1000 ~ 150
1500 ~ 150
2000 ~ 150
2500 ~ 150
3000 ~ 150
3500 ~ 150
4000 ~ 150
4500 ~ 180
5000 ~ 210
5500 ~ 210
6000 ~ 240
6500 ~ 240
7000 ~ 270
8000 ~ 270
9000 ~ 270
t*wat Map Screen 28
ANd the rest are zero
Option Map
Screen 30
Af_StE ~ 10
Dwell ~ 3.25 *set at Time Base - not at Duty Cycle*
REVstg ~ 1320
MAPstg ~ 02"
%stg ~ 50
Old May 5, 2011 | 05:10 PM
WLD 07's Avatar
Here is a map Rx72c posted with the same injectors you have.
Should give you something to start from.
https://www.rx7club.com/microtech-111/can-someone-write-me-tune-807780/
Old May 6, 2011 | 12:22 PM
nuimpykid's Avatar
That is what i used, wont idle at all. Hopefully I can mess with it some more this weekend and try to get it to idle.
Old May 7, 2011 | 05:15 AM
rx72c's Avatar
Top Answer: 1
Idle Map
30" ~ .95
25" ~ .95
20" ~ 1.04
15" ~ 1.24
10" ~ 1.51
05" ~ 1.91
00" ~ 2.14
2-20psi ~ 4.95
Try that. Let me know if it gets better or worse.
Old May 7, 2011 | 08:22 PM
nuimpykid's Avatar
rx72c- I got it to idle earlier today. Here is where it is at.
30" ~ 2.67
25" ~ 2.90
20" ~ 3.24
15" ~ 3.43
10" ~ 3.62
05" ~ 3.05
00" ~ 3.62
2-20psi ~ 4.95
I am not sure why my dwell times are so much higher than yours. It was idling smoothly at about 1100 warm. I drove it around a little bit, and when coming to a stop, the idle would surge for maybe 10 sec. then level back out at 1100. Afr was 12.3-11.7 or so. Seemed decently smooth. Do those settings seem ridiculous?
I just went out and put your values in, it would not hold an idle. Afr was pegged at full lean. I put my values back in.
Here is my 1000 map
30" ~ 0.81
25" ~ 1.05
20" ~ 1.29
15" ~ 1.81
10" ~ 1.81
05" ~ 3.29
00" ~ 3.81
2psi ~ 4.76
I did not get into boost at all, so that 2psi is probably off, as well as the 00". Does this seem strange? The idle seems strong. Pulls about 15" at idle, maybe 18" I am running 93 oct with premix. Omp is eliminated. I was sitting in mid 13 afr at light load cruise. Maybe a little leaner in some spots. I can post more if you need. I am just learning how to do this, im sure its not exactly right.
Thank you for the help.
Old May 8, 2011 | 07:46 AM
bumpstart's Avatar
talking head
if i run 50 % stage value with 1000 primaries i use around . 1.1 -1.3 ms for the 30, 25, 15 " Hg idle and load maps
this will give 1.65-1.95 ms on the handset while not staged
( thats the quirk of how the staging value works in micro algorithm )
that will work well for most extendies with 1000 cc type rochies and around 33 psi on the FPR during idle
( 40 - 42 psi base pressure ( atmo ), 15 -20 "Hg idles )
if your using values higher than this,, then you need to check fuel pressure
or you need to make sure they are 1000 cc primarys
if i was seeing 2.67 ms on the handset pre staging with 50 % staging then i would be using a map with 1.7-1.8 values in it
that is very close to numbers i would expect to see when using later s4/5 ( saturated ) injectors with 50 % stage value
Old May 8, 2011 | 11:57 AM
nuimpykid's Avatar
Fuel pressure is at about 34-36 psi at idle. 39 psi atmosphere. However idle was only pulling about 10" cold. Did not have the car all the way warmed up. I have a sard Fpr. -6 lines from tank up.
I sent these injectors to RC and had them bored to 1000cc. They sent a flow sheet back with them, and they are now engraved with rcx-1000? Something like that. They were stock cosmo side feed 550's.
The numbers I gave were directly from the laptop.
Old May 8, 2011 | 06:57 PM
rx72c's Avatar
Top Answer: 1
with those numbers they are 500cc injectors.
No offense. I just pulled those numbers out of a car that had proper 1000cc injectors
Either that or your voltage is very very low. What is your voltage at your microtech(your injectors share the power wire for you microtech)
red wire on your harness. Should have at least 13.5v
Old May 8, 2011 | 08:34 PM
nuimpykid's Avatar
Can I go by the voltge shown on the laptop screen? Or do I need to actually put the volt meter on the red wire?
Old May 8, 2011 | 08:52 PM
bumpstart's Avatar
talking head
yes,,- usually micro display voltage at the micro is fine
but just double checking it at the injector may show up a poor connection and is worth confirming
you should also be giving us the numbers in the map itself,,, or telling us if the numbers posted are displayed on the handset
( as i have pointed out ,, the staging algorithm will be adding 50% to the map value while not staging )
if using the real time display you should also be waiting till the engine is near 80C to get the numbers
-- else they will be all crooked with cold warm up correction
if you go to the idle and load maps ,, what is in the -30, -25,-20 and 15 " Hg bins?
30" ~ 2.67
25" ~ 2.90
20" ~ 3.24
15" ~ 3.43
10" ~ 3.62
05" ~ 3.05
00" ~ 3.62
2-20psi ~ 4.95
this? /\
or \/ this ?
30" ~ 0.81
25" ~ 1.05
20" ~ 1.29
15" ~ 1.81
10" ~ 1.81
05" ~ 3.29
00" ~ 3.81
2psi ~ 4.76
the lower one is entirely what i would expect from 1000 cc rochys
the upper one is something close to stock injectors especially around idle
am very suspect as to the quality of the injector bore job,, or that these injectors have very significant lag periods
not something i would gamble on,,,, go straight to marren and order the import ( 11mm top ) matched rochies
Old May 8, 2011 | 11:44 PM
nuimpykid's Avatar
The numbers I posted were with the car off/cold. Did not realize that they would change on the laptop based on the water temp correction.
I have not touched the load map at all. It is what I put in from rx72c.
Load Map
Screen 3
30" ~ 0.95
25" ~ 0.95
20" ~ 1.13
15" ~ 1.44
10" ~ 1.81
05" ~ 2.24
00" ~ 2.56
2psi ~ 2.2
4psi ~ 3.4
6psi ~ 3.9
8psi ~ 4.6
10psi ~ 5.1
14psi ~ 5.7
16psi ~ 6.0
18psi ~ 6.6
20psi ~ 7.1
The bottom map that you posted is what my 1000 rpm map is. But since my car idles at 1100 when warm, does that make the idle map null? Am I just being stupid? It would not idle on its own cold.
I think I may be an idiot.
Old May 9, 2011 | 07:01 AM
bumpstart's Avatar
talking head
the map plots are for every 500 rpm when in matrix mode so the ecu will co-relate the number based on its position between 1000 and 1500 maps
if you get no result with the highlighted direct map , its always worth pushing the plots either side of it to change the ramp
you should warm the car and do all changes to the plots when the maps have no added coolant correction factors
later,,on subsequent mornings the coolant and cranking maps can be tailored and it may take a few days to beat the bumps out of the tune as the engine progresses through warm up
you can cheat the process to learn if you need more or less at problem temps by using the mixture trim up then down to get a feel for the coolant map bumps and valleys
once you establish the correction needed you re-zero the mix trim and put the correction instead directly in the coolant correction maps for the appropriate temps
the numbers you have for -30 to zero at 1000 rpm from rx72c here should be also repeated in the 500 ( idle ) map else the motor will stall
( there is a little idle /start glitch that comes with matrix mode unless you match these )
if you do this the motor will run and the map will work of sorts
i disagree however with the main basis of the tune with its staging flags being set to basically all injectors at anything other than idle
its not making the best of the reasons for sequential staged injection
and as such having a % stage at 50 % does not also suit the fact injectors are 1000 and 1600
( 50 % is intended for when all injectors are same )
if you have 1000 and 1600 combos and you wish to retain the advantages of proper staged sequential injection
then the staging thresholds will be 3000- 3500 rpm and around 2 psi
this will be where the 1000 cc primaries will be pushing about 65 % duty
-much like the factory ecu will ,, -give take-
to kick them in smoothly with the secondaries approx 50 % or larger than the primaries then the stage algorithm will work with numbers in the 65-75% regions
if you already have a working 1000 x 4 map then there is an easier way to get the map up quickly if you sub in 1600 secs
the staging algorithm should go to 75 %
this will make the 1000 primaries too rich pre staging ( by 25 % )
the 1600 secs will also make the entire full load make approx 25 % richer
( 2000 cc V 2600 cc each bank )
so,, obviously,, pull 25 % out of the mix trim
this will make the real time idle number displayed on the screen back to the same number it always was with 1000 x 4 map
it will also pull 25% out of all of the full load maps,,, back to the same AFR's it always was with the 4 x 1000 map
however,, you will have 25 % more duty time avail for further fuel should you wind up the boost or find need for more
Old May 9, 2011 | 07:57 PM
bumpstart's Avatar
talking head
edit to above,, if you have side feed injectors the top feed marrens/rochys will be no good for you
Old May 10, 2011 | 01:26 AM
nuimpykid's Avatar
So from the looks of it, I need to match my 1000 map and my idle map and see what happens. I will warm the car up in the morning and see what happens. Thank you for the explanation on the coolant correction, when I get to that point I will def use your advice.
Rx72c, your saying I should see 13.5 volts at idle? Also, I have a gilmer drive on the car, i had heard that it underdrives the alt pulley.. So what should I try and idle at? Also, like I asked above, since the car idles at 1100 warm, does that mean its going off the 1000 map and not the idle map?
Old May 10, 2011 | 04:12 PM
rx72c's Avatar
Top Answer: 1
are you using normal mode or matrix mode?
is your tps calibrated?
Old May 10, 2011 | 07:36 PM
nuimpykid's Avatar
Matrix. I believe so. It has always been sort of funny. I believe its a cosmo tps, cosmo intake... when you push the pedal like 1/8 it shows full throttle.. is that wrong? It was like that when it was dyno tuned before also. Never knew if it was really right or not.
Old May 10, 2011 | 10:16 PM
rx72c's Avatar
Top Answer: 1
well your applying a normal map to a matrix map. ...
voltage should be at least 13.5 as per handset what is your voltage on
Old May 10, 2011 | 10:46 PM
nuimpykid's Avatar
@ idle it varies. Sometimes it will sit at 11.5 sometimes it will be 14.5. A 180 amp fd alt is going on this week.
Dont I just copy the load map to all screens but idle/1000 and start from there? Thats what the manual says.? IDk.... Its my first time.
