Megasquirt MSI to MSII quick question
Old Apr 16, 2011 | 11:02 AM
barnett87rx7's Avatar
lite rotary = easy push
From looking at the msextra website am I correct that when I install the MSII daughterboard in my MSI v3.0 board I only need to wire S12c(12v) to JS9 on the daughterboard?
Is there anything else that needs to be wired?
Old Apr 16, 2011 | 02:06 PM
Eagle7's Avatar
Do you have a dual VR wheel configuration? Did you build the second VR circuit in the prototype area? There is a recommended mod for this circuit for MS2 operation since it is interrupt driven rather than polled.
Old Apr 17, 2011 | 09:49 AM
Aaron Cake's Avatar
Engine, Not Motor
Yep. Just make sure that your ignition setup is correct based on the setting on the board (MSI is physically configured for VROUTINV, while the MSII is software selectable).
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
