Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
12a PP dyno
Old Apr 6, 2011 | 01:37 PM
gusfd3s's Avatar
E85 Addict
12a PP dyno
a friend of mine built this 12a PP engine, dont know the specs but im sure he'll chime in..
Old Apr 7, 2011 | 12:00 AM
t-von's Avatar
Rotor Head Extreme
Crank hp or rear wheels?
Old Apr 7, 2011 | 12:28 AM
Narfle's Avatar
Rx7 Wagon
Nice. I likey.
Old Apr 7, 2011 | 08:00 AM
gusfd3s's Avatar
E85 Addict
this is crank hp, super flow dyno..
Old Apr 7, 2011 | 12:54 PM
Doc Holiday's Avatar
Needs more cow bell
I'd like to know what size carb and what size header tubes and length. I'd be thrilled to make these kind of numbers and I'm using a 13bpp lol.
Old Apr 7, 2011 | 01:00 PM
sen2two's Avatar
Rx2 > FD
I am very interested in the details! I am building a 12a PP right now!
Old Apr 7, 2011 | 01:23 PM
gusfd3s's Avatar
E85 Addict
48mm ID if i remember correctly.. equal length.. i dont know more info but ill try to get him on here tonight.
Old Apr 8, 2011 | 05:49 AM
Lasse wankel's Avatar
The id of headers is 48 mm and 800 mm long with 15 deg collector and one 3" straight thru muffler- RB dizzy with 2 MSD 6AL2 (the new version)Blaster 2 coils. 48 mm IDA carb with 42 mm chokes. ID in rotor housing is 43 mm venturi. Problem was that the carb leaned out over 8000 rpm to 14.8-15.2 AFR. We rejet it from185 main to 290 with lots of fuel curves, even bored out the needle valve to 3.3 mm, but same problem occured. The exhaust temp was 1420-1440F, almost identical which i've never seen before with a dizzy. Timing was 24L16T. Not satisfied with these numbers i will go back to the dyno in about a month. Hopefully the fuel curve is sorted out and 280 hp is achived...
Old Apr 8, 2011 | 03:03 PM
ultimatejay's Avatar
Your EGT temps are too low and that choke is really small unless you want alot of bottom/midrange power. I notice you fall off at 8000rpm. That is pretty low for a pport. I would try a larger choke. AT least a 45- 46mm.
Old Apr 8, 2011 | 03:49 PM
ApexMutt's Avatar
I'd do horrible things to/for those headers.
Old Apr 9, 2011 | 02:42 AM
Needs more cow bell
Thanks for the info on the setup, I really appreciate it.
Old Apr 9, 2011 | 12:10 PM
gusfd3s's Avatar
E85 Addict
made a new header that will be on a 12a BP motor that will be dynoed this tuesday.. its a little shorter (600mm) but will be adjustable up to whatever length it likes.
Old Apr 17, 2011 | 01:26 PM
Did some dyno testing with a 12A standard bridge engine.235 stp corrected@9000 rpm and 210 Nm@7200 rpm. Same 48 IDA as on the 12a PP ,motor but with 44 mm chokes and 250 main and 140 air jets. ignition made best power at L25 T18 with the MSD 6AL2. The primaries was the same as on the PP motor.
/Lasse
Old Apr 17, 2011 | 06:12 PM
fidelity101's Avatar
Rallye RX7
I have a lot of experience with Superflow dynos and flow benches, they are my favorite hands down. Good stuff!
Old Apr 22, 2011 | 02:44 PM
Tommy2Tone's Avatar
Great setup!
Old Sep 9, 2022 | 08:37 AM
Rx-7Online's Avatar
New to the Club!
/Lasse
Hello! Could you send me information about the structure of the complete ignition? Have a 12A PP built after the pattern of Mazda Race, he runs well....but with the original ignition is from 6000 RPM end and there the power should only begin ... Carburetor is a 48er Weber ... Thanks in advance - Charly
Rotate86
May 18, 2018 02:44 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
