13b-re 87t2
Old Mar 31, 2011 | 06:37 PM
drifting in drifting's Avatar
PA 13b-re 87t2
So I went to KDR and had Dave do his magic this tuesday.
368hp 311tq on a dynojet.
Old Mar 31, 2011 | 09:45 PM
Nick_d_TII's Avatar
Nice.. so you ditched the rtek? Weren't u running rtek? Good job tho! Vids?
Old Mar 31, 2011 | 09:55 PM
tuscanidream's Avatar
T2 Duo!
Details on build?!?!?!
Old Mar 31, 2011 | 10:09 PM
Yeah i got a good deal on a lt10s
720/1000 24k japan2la RE longblock,to4s/.81 water injection
I will post the sheet once i get it to scan
Old Mar 31, 2011 | 10:20 PM
sheet
I still need to replace my synapes spring to the stiffer spring. Dave seemed to think it will help spool alot sooner
Old Apr 1, 2011 | 05:02 PM
Changed to the 60/lb rate spring and about half way in on the preload.
Snappier than hell now!
Old Apr 26, 2011 | 07:04 PM
I still would like to improve spool.Im not really getting full boost 15-18 until over 4000.
I really thought id have full boost sooner but i can only point my finger at the dam exhaust sleeves
Old Apr 28, 2011 | 08:02 AM
Len-Len's Avatar
Lenny
Damn decent torque curve. Things gotta be a hoot to drive.
Old Apr 28, 2011 | 08:06 AM
Yeah it spins at the top of 2nd an 3rd alittle but i have new 245/45/17s so its biting pretty hard
Old Apr 28, 2011 | 05:26 PM
BOOST LEAK
I've had a leak when i got it tuned
A bad one at the idle screw on the upper intake and 2 ic couplings
So now i know its putting it down alot harder than after i left Daves.
But i still have a leak and its my fuel pressure regulator it leak around the adjustment bolt not alot but it leaks. Making progress.
Old May 9, 2011 | 08:36 PM
JaredCarpenter's Avatar
What intercooler setup are you using?
Old May 10, 2011 | 05:13 PM
Nothing special i think its an ebay one
Old May 10, 2011 | 05:24 PM
Nick_d_TII's Avatar
Nice! Bet that's a fun ride!
Old Jun 12, 2011 | 08:08 AM
Ahh it all went to **** i cant boost over 14 psi again feels real slugish. If i have to get it retuned I maybe selling the whole setup and going 20b. I know the ecu is good and the engine is outstanding
Old Jun 12, 2011 | 10:55 AM
junito1's Avatar
F**K THE SYSTEM!!
Wat do you mean it went to ****? YOu popped the motor?
Old Jun 12, 2011 | 10:45 PM
Hell no. I got it tuned and then found a boost leak fixed it. and it messed the map up alittle then i started having problems with it breaking up over 14psi.
If i dont get it to rnn better before winter I might sell the longblock and lt10s.Engine pulls 21 vacumm at idle and 110 or better compression.
Old Jun 23, 2011 | 03:36 PM
So tomorrow is payday so hopefully i can order a set of plug wires and a new wb sensor.
I have switch from the bosch coils to 4 fc trailng coils in hopes of stronger spark.
Any thoughts are welcome.
Old Jun 25, 2011 | 12:07 PM
BOSCH COILS SUCK!!
I put 4 fc trailing coils on and my midrange power went through the roof plus no breakup.
So it looks like ill be going to Daves again
Old Jun 30, 2011 | 05:36 PM
Japan2LA's Avatar
Originally Posted by drifting in drifting
BOSCH COILS SUCK!!
Hard to beat stock FC coils lol...
Old Jun 30, 2011 | 10:57 PM
Yeah i wish i knew this a long time ago. I have a older f250 thats getting a mazda coil.
Old Jul 6, 2011 | 11:10 AM
funkjaw's Avatar
Update please did you make it back over to tune it yet?
Old Jul 6, 2011 | 04:46 PM
probably wont happen till fall now.I fixed the few spots in the map it messed up no its better than when i came from Daves. Now i need new engine mounts
Old Jul 7, 2011 | 07:37 PM
funkjaw's Avatar
^ Yeah that's sounds like an Rx7, one thing after another haha.
Old Jul 25, 2011 | 10:06 PM
Yeah i would compair a 7 to a 2 stroke racingbike fun when running but when not its usualy a pain in the ***
Old Nov 17, 2011 | 10:19 PM
Went down again and did 380 this time .The exhaust sleeves really need to come out. maybe next winter.Ill save up parts till then
