Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek will 1000cc injectors
Old Mar 20, 2011 | 12:23 PM
dennis blackstone's Avatar
i have my rtec 2.1
but all i have are 2 1000cc injectors for secondarys
can i use the 550s for primarys
with a bnr turbo stage 2
will it stumble and act up
or can it be done with no problem
i have a 87 t2
walboro fuel pump
fmic
Old Mar 21, 2011 | 10:25 AM
turbo2ltr's Avatar
Having injectors that are very far apart in flow ratings are not recommended.
Old Mar 21, 2011 | 07:31 PM
what do you recomend
Old Mar 21, 2011 | 08:52 PM
rx7 FC TII's Avatar
Semper
720cc secondaries.
Old Mar 21, 2011 | 11:26 PM
RotaryRocket88's Avatar
Top Down, Boost Up
4x 720cc injectors will be just enough at reasonable duty cycles.
Old Mar 22, 2011 | 09:43 PM
has anyone got any decent hp with this set up
Old Mar 23, 2011 | 07:08 AM
Clubuser's Avatar
get some 750cc for the primary and you'll be set. There are Rtek7 2.1 setups claiming low 12 sec ~115 mph trap speeds with similar fuel capacity = very respectful HP. My Rtek7 1.8 cycles the 720's @ ~ 5-6% duty cycle @ 900 RPM which equates to over 3 ms pulse width so there's plenty of room for idle adjustments with the 750's.
Old Mar 23, 2011 | 07:38 AM
bikeboy23332's Avatar
i put in 720 1000 setup in mine but it wont run on the 720/720 setting. it only runs and idles on the 550 550
Old Mar 23, 2011 | 09:28 AM
lastphaseofthis's Avatar
My job is to blow **** up
You're doing it wrong....
maybe the start map got wiped flat when you changed it over... i would at least run the 550/720 setting..
Old Mar 23, 2011 | 12:14 PM
10AEinIOWA's Avatar
Does any one know if i will have issues with 550 pimaries and 750 on secondaries?
Old Mar 23, 2011 | 02:27 PM
Top Down, Boost Up
What fuel pump and FPR? If walbro 255 and a stock FPR, you'll end up with excessive fuel pressure at idle/low throttle.
Not if you're using the 550/720 setting. The difference between 2600cc (2x 550 + 2x 750) and 2540cc (2x 550 + 2x 720) is only 2% additional fuel when the secondaries are active.
Old Mar 23, 2011 | 06:27 PM
i have also a 255 lph and stock fpr
what should i do to make this work
i see some use 720 asome use 750...where can i get the 750s if there better
Old Mar 23, 2011 | 08:20 PM
Clubuser's Avatar
Not that they are better. Check the price on these low impedence type and compare to the 720's (nippon denso?). I think you'll find new 720's to be quite a bit more:
http://cgi.ebay.com/ebaymotors/2-Sie...Q5fCarQ5fParts
Old Mar 24, 2011 | 09:05 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
720/1000 cc injectors worked well for me. 720/720 setting
Old Mar 27, 2011 | 06:30 PM
do you have your settings to share with us
Old May 13, 2012 | 06:04 PM
hiroichi1515's Avatar
im running 850 /1000 with a walbro 255lph on the 720/720 settings. The fuel map fields in the cruising areas are all over the place but it works well with this setup.
Old May 28, 2012 | 03:34 PM
Well after some consideration I changed my settings to 550/720. Pulled about 28 - 31 from 2psi to all vaccum. Then used solareons fuel map in boost areas and still had to pull that alot. So far I'm up to 13 psi with a 68.74 duty cycle. Afrs seem to run around mid 11's sometimes hits 10.9. It feels good but I want to hit the 320hp mark. I'm hoping this can be reached at 17psi
Old May 29, 2012 | 11:04 AM
Clubuser's Avatar
Originally Posted by hiroichi1515
...... It feels good but I want to hit the 320hp mark. I'm hoping this can be reached at 17psi
You do know the MAP sensor is limited to <15 psi. If your engine is ported and100% sound, 320 whp is reached @ <15 psi via RPMs.
Old May 29, 2012 | 11:53 AM
K-Tune's Avatar
FD Daily
I've used 720/1000 and even 720/1600 with rtek 2.1 without any issues.
Be careful when exceeding 15psi on the stock map sensor...
Old May 29, 2012 | 12:46 PM
Yep. I'm using water injection to try and help prevent any issues up there. I have enough fuel for it. My setup is....
S4 N/A keg with fd oil pressure regulator (otherwise stock)
S4 hybrid, to4b v trim wheel, 38mm wastegate
Fmic, mounted in the spot of the radiator
2.5 dp and mid to 3 cat back
Walbro 255
820cc / 1000cc
400cc water injection pre turbo
Apexi AVCR boost controller
In reading that preturbo injection will move the compressor map up and the right, I hope to still be in the efficiency range at the psi. My goal is 320rwhp. True I may be at that now but I don't have anything to compare it too . If I don't reach that amount by 17psi I'm not going higher but I really would like to see what it's like.
Old May 30, 2012 | 09:22 AM
t2ae's Avatar
so i just got my rtek 2.1
my current setup.....s4 turbo motor with minor streetport
bnr stage4 turbo with full racing beat exhaust
fmic with tial b.o.v
all emmisions removed
act 6 puck with 17lb flywheel
rc 550cc/1000cc
walbro 255lph
with this being said what shold be a good primary setup to use to go to the dyno to fine tune?
550/720 preset? any help or maps would greatly be appreciated!
Old May 30, 2012 | 09:59 AM
550/720
Old May 30, 2012 | 05:12 PM
sharingan 19's Avatar
Rotary Revolutionary
you'd be better off with 720 primaries considering the air a stage 4 bnr can move and the rather large transition from 550 --> 1000. How much boost do you plan to run?
Old May 30, 2012 | 05:29 PM
JWteknix's Avatar
I have no issues running 550/1000cc on the 550/720 setting
Old Jun 1, 2012 | 05:59 AM
t2ae's Avatar
planning on running as much as possible and be safe, so im assuming max will be 15psi b/c of the factory sensors. is there anyway around that to push more that 15psi and be safe?
