AUto X Tire pressure question???
Old Mar 18, 2011 | 06:14 PM
roondawg's Avatar
I am running a GSL_SE with 14inch konig wheels and Falken RT615 tires. Where should I start on tire pressures? This will be the first time running these tires, and I am going to play around a little during the event trying different pressures, just not sure where is best to start.
Old Mar 20, 2011 | 05:34 PM
Kentetsu's Avatar
Use a bit of chalk or white shoe polish on the sidewalls. If the tire is rolling over onto the sidewall during your runs, add more air.
With 215/50/13 Sumitomos, I run in the upper 40s to 50 psi.
Old Mar 22, 2011 | 12:56 PM
unlimitedrotations's Avatar
you gonna learn today
agree with chaulk every tire and rim and car is setup up differently i usually start at 35 though and go from there
Old Mar 22, 2011 | 12:59 PM
evot23's Avatar
Classy
35 cold psi..then go from there as stated above.
Old Mar 23, 2011 | 08:35 PM
roondawg's Avatar
Thanks, I ran a 32 front and 30 rear. Finished 1st in ES class. I could have used a little more in the front.
Old Mar 23, 2011 | 08:56 PM
evot23's Avatar
Classy
congrats!
Old Mar 27, 2011 | 12:01 PM
good job man
maikelc
Aug 24, 2015 11:04 AM
