Swapping '90 Motor into '87 Chassis N/A
Old Jul 8, 2002 | 02:41 PM
SoloIIdrift's Avatar
Question Swapping '90 Motor into '87 Chassis N/A
Okay, well it's come down to the final days.
I was wondering how people routed the vacum hoses and got the 6 ports working. If someone has done this swap I'd love to hear problems and solutions you encountered.
I'm getting a rpm switch for the VDI
It's set in stone that I'm keeping the S4 ECU, wiring, thottlebody, and OMP (obviously).
Any tips on routing the ACV vac hoses to the FPR?
Old Jul 8, 2002 | 03:27 PM
Silkworm's Avatar
Has been.. hangin' around
Well, I've done the swap, but didn't keep a single piece of smog equipment, so I can't help..
I can tell you that the 89 runs just fine the way you are going about it though, I have the same setup (sans smog of course)
PaulC
Old Jul 8, 2002 | 03:59 PM
Cool! Well thats good, I'm using the S4 front cover and water pump. It's just the damn Vac lines.
How did you get around the fuel pressure regulator issue with the vac lines going to that from the manifold pressure to atmosphere pressure form the ACV to the Fuel pressure regulator?
Old Jul 8, 2002 | 04:11 PM
Silkworm's Avatar
Plugged the Fuel pressure vac inlet Sends it into high pressure all the time. Not something you can get away with on a street car, but my car, aside from warmup, spends all of it's time between 4000-8000 RPM.
PaulC
Old Jul 8, 2002 | 08:53 PM
Ha, Cool Paul, but yeah I'd like to see some gas mpg...
Anyone else? I know there's other's that have done this..
Azevedo
26
Mar 1, 2019 09:19 PM
hotshot2014
Jul 18, 2017 02:30 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
