Air pump removed
Old Mar 11, 2011 | 05:36 PM
Linguo415's Avatar
Air pump removed
I'm taking my turbo out of the car to have the waste gate ported. My question is can I drive without the airpump?
Old Mar 11, 2011 | 09:33 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If you have a catalytic converter, I wouldn't.
If you don't, you don't need the air pump.
Old Mar 12, 2011 | 01:37 PM
Linguo415's Avatar
Ya. I have a main cat. also when disconecting the down pipe the wire for the 02 sensor snapped. What can I do to fix this?
Old Mar 12, 2011 | 01:45 PM
boostedfc3s's Avatar
1.3 liter piston eater
If the wire to your 02 sensor broke on the sensor side of the plug. Go buy a new 02 sensor, it comes with the wire and plug on it.
Old Mar 12, 2011 | 09:33 PM
Linguo415's Avatar
The wire snapped closer to the other end. I'm not sure where it goes because it dissapears under some tape and what looks like the rest of the engine harnes.
Old Mar 13, 2011 | 03:58 PM
Just going to have to open up that harness and find the break and repair the wire.
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
