wrong gas
Old Mar 11, 2011 | 04:53 PM
hvaltierra's Avatar
Angry wrong gas
so i wasnt paying attention when i filled up a bit ago and i accidently put about 9 gallons of 87 into my TII i then once i noticed what i did i stopped the pump and put 5 gal of 91 so there was another 4gals of 91 in the tank so half 87 half 91. stock motor fuel exhaust. will it be ok. should i drive like an old lady or siphon all the gas out.
Old Mar 11, 2011 | 04:55 PM
RotaryRocket88's Avatar
Top Down, Boost Up
87 octane is the recommended fuel for a stock TII.
Old Mar 11, 2011 | 04:56 PM
w0ppe's Avatar
CC of L-Squared Shots
I'm a touchy kind of person and I would siphon it out...
It won't blow up your motor but it'll run like crap until the fuel is gone. Just be careful when driving it...
Old Mar 11, 2011 | 05:49 PM
FC_fan's Avatar
Sideways is the only way
unless it says "premium fuel only" on your cluster then you can run any of the regular octanes 87-93. it is recommended to use 87 actually though.
Old Mar 11, 2011 | 05:52 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
it wont run like crap, it will actually probably run better.. just dont boost. I will fill up with 87 on long road trips some times to be cheap, just cruising and staying out of boost
Old Mar 11, 2011 | 05:56 PM
SPENT-IT's Avatar
10/6
Pour in some octane boost.
Old Mar 11, 2011 | 06:33 PM
rx7racerca's Avatar
If it's stock, it will make no difference at all - and next time, you can just fill up on regular and save your money, throwing premium at an engine that doesn't need it/isn't tuned for it is just wasted $$$. It doesn't improve performance, and stock there is generous allowance so it's not giving meaningful extra margin against detonation even.
Old Mar 11, 2011 | 06:40 PM
Evil Aviator's Avatar
Rotorhead
Why are you using 91?
Anyway, if you are wondering about mixing, half 91 and half 87 would end up pretty much like 89 once it is mixed thoroughly. It is a little more complicated than that, but that is the basic overview.
Just to clarify, 87 is the minimum recommended octane. You can use higher octane if you like, but unless the engine is in poor shape or overboosted then the higher octane will make no difference other than costing more money. In many cases the higher octane yields slightly less power and slilghtly worse gas mileage, but it is negligible.
If the engine is stock and in good shape, it will run just fine since the TII is rated for 87 octane. Sometimes 87 will even run better than 91, depending on the mixture used by the fuel vendor.
Old Mar 11, 2011 | 07:24 PM
Derekcat's Avatar
Rotary Zealot!
Just to reinforce once more:
For all stock FCs: Run 87 Octane.
[The End]
Old Mar 11, 2011 | 07:34 PM
SPENT-IT's Avatar
10/6
True ^ I was going the quick fix safer than sorry route.
He didn't say what he had. Modded high boost or stock.
Money in your pocket is good for more drive time.
Old Mar 11, 2011 | 07:37 PM
oinesra's Avatar
You are fine.
But if you do feel the absolute need to get it out, there is a drain plug on the bottom of the tank. No need to siphon it out.
Old Mar 11, 2011 | 08:43 PM
K-Tune's Avatar
FD Daily
Very wrong.
Stock boost means 87 octane, no exceptions. Unless you want even poorer mileage and more carbon buildup.
To the OP...just drive your car.
Old Mar 11, 2011 | 09:44 PM
bumpstart's Avatar
talking head
when i was in colledge i had a lecturer explain exactly what happens when you blend two octanes to a perfect 50/50 ratio
the result is not as expected,, and the discussion on the matter was lively
( i will point out this bloke was teaching us the petroleum industry processes )
i was at that point advocating what you wrote,, but apparently it is not so ,, and the reasons complicated
( something to do with hydrogen bonding / van der waals ratios )
for the OP,, it will not matter that much,, drive it for a short distance conservatively ,, and refill with your normal choice
where i am in western austraila,, octane is rated in RON ,, and so the numbers don't co-relate with your grades
-- however,, on any aftermarket tuned rotary,, using the standard 91 RON
( about 86 combined ron/mon )
can be engine lethal in hot ( 100 F + ) conditions
here,, the better tuners tune for 8/10's cause the petrol quality from the pump can vary in hot conditions
- pulling 2 degrees out of the optimum timing is considered normal practice
Old Mar 11, 2011 | 09:47 PM
Rotorhead
Originally Posted by K-Tune
Very wrong.
Higher octane will not cause more carbon build-up. That is just an urban legend based in the misconception that the octane rating is related to the burn rate, which it is not. Higher octane fuel may cause poorer gas mileage, but the amount is usually insignificant. Pump gas from the same vendor is all pretty much the same, with the only real difference in grades being the knock resistance and price.
Old Mar 11, 2011 | 11:27 PM
canonize-ryda's Avatar
what about stock na fcs? 87 as well? and what about na with full exhuast and intake use?
Old Mar 11, 2011 | 11:37 PM
1SWEET7's Avatar
Now With 10th AE Fun!
What fun is driving on stock boost? I have posted it before, but I have a stock sticker on my 10th AE that says run 92 octane fuel or higher... It says it on my filler cap too which is stock. Very weird. Not like you can get 92 in Ca anyway I don't think, and my car has always been a Ca car. I run 91 always, but I run 11-12psi too.
Old Mar 11, 2011 | 11:38 PM
SirCygnus's Avatar
whats going on?
for all na? USE THE LOWEST YOU CAN FIND!
Old Mar 12, 2011 | 12:01 AM
nycgps's Avatar
PedoBear
I can't believe people still have NO FREAKING IDEA what the "Octane" rating means on the pump.
and Im even MORE surprised that owners these days have absolutely NO IDEA of what gas they need to use.
Old Mar 12, 2011 | 11:31 AM
Rotorhead
All stock 86-92 RX-7s are rated for a minimum of 87 octane using the R+M/2 method, and a maximum of 10% alcohol. It states this quite plainly in the owner's manual.
For the most part, you don't need to worry about the octane of the fuel with an NA rotary engine unless the engine is running very high compression rotors, highly advanced ignition timing, a very lean fuel mixture under load, or highly contaminated with carbon deposits. I am not aware of any professional rotary race cars which require high octane fuel, so your street RX-7 should be fine unless you really screwed something up.
A previous owner probably put those stickers on your car. Some of the cars sold in Canada had RON stickers, but I think those were 90. Look at your owner's manual and see what it says in there. If it has something other than 87 R+M/2, then the car was sold in a region using RON rather than R+M/2.
That's actually also a misconception. In the book, "How to Modify Your RX-7" by Dave Emanuel, Rick Engman stated that he found better results with "very low-octane fuel" and conservative (optimal) ignition timing as opposed to high octane fuel with highly advanced timing. People misconstrued this to mean that a lower octane rating always means higher performance. What it really means is that advanced ignition timing is not optimal, and that lower octane fuel tends to have more energy content. Since the energy content of pump gas does not vary much throughout the various octane grades, the main point here is to focus on tuning the ignition timing for optimal results. Simply dumping low octane fuel in your fuel tank will not make much performance difference if you have not fine-tuned your engine with an aftermarket fuel computer, however you will at least save money.
For reference *:
Chevron UTG-91 (86.8 R+M/2): 18500 BTU/lb
Chevron UTG-93 (89.3 R+M/2): 18300 BTU/lb
Chevron UTG-96 (91.6 R+M/2): 18400 BTU/lb
This shows that the high octane test fuel actually has more power than the mid-grade in this case. The power difference between the low grade and high grade is only about 1/2%, which works out to less than 1hp on a stock NA RX-7. Other brands of pump gas will have different statistics, blends also vary with specific regional standards, winter fuel is different than summer fuel, and race fuel is totally different.
* Chevron has since changed their test fuel from what is listed above, but they no longer publish the energy content, so I used the older 01/30/07 stats.
This is a very confusing subject. I have experience running a fuel farm and international fuel contracts, but I do not have the level of understanding that my chemists did. Those guys are something else, and it isn't reasonable to think that the average forum members would have that level of education and comprehension. However, you would think that the forum members would at least open the owner's manual to see what it says about fuel.
Old Mar 12, 2011 | 12:53 PM
Spectrum24x's Avatar
Coolant Leak
Can we define "stock turbo 2" I have Greddy fmic and apexi n1 with 720 secondaries. Am I wasting my money on 93 octane?
Old Mar 12, 2011 | 01:23 PM
Rotorhead
Stock = how it came from the factory. Once you start screwing with the boost level, fuel system, and ignition timing then it is no longer in the original stock form. Since your car has a modified fuel system and probably a higher boost level, then you should use whatever fuel was recommended by the tuner.
Old Mar 12, 2011 | 02:33 PM
hvaltierra's Avatar
ya my motor is stock just an exhaust from the down pipe back with no cat. other than that fuel ign is all stock. thicker wires is about it. thanks for the advice guys.
Old Mar 15, 2011 | 11:42 PM
hvaltierra's Avatar
so heres an update car actually got about 50miles more out of the tank with the mixed gas. only prob now is ive been overboosting for a bit and today i gave it a little to much pedal in third and ping ping boom. now i need a rebuild sucks *** to beacuse this motor only had about 30k on the rebuild now. :0(
Old Mar 15, 2011 | 11:46 PM
Top Down, Boost Up
You have to port the wastegate, even with an S5 turbo. Opening up the exhaust will lead to creep. http://fc3spro.com/TECH/HOWTO/KWG/kwg.html
Old Mar 16, 2011 | 06:17 AM
Pele's Avatar
Right near Malloy
I thought you said everything was stock!
Case in point everyone... COMMUNICATION!
Proper punctuation and giving as much info as possible will help others help you.
Someone mighta caught on earlier had you said the exhaust was modified.
Sorry for your loss man.
