yes...i know another idle problem
Old Mar 8, 2011 | 07:52 PM
aimfabrication's Avatar
newbie wanting to learn!
Exclamation yes...i know another idle problem
ok i adjusted the tps the ohm resistance way to 1k. the idle bumps from 1200 to 1500 still. after full warm up i adjusted it again and nada! same problem.
i need to smog the car this month so i dont know if that will affect it passing.
Thanks for your time.
Alex
Old Mar 8, 2011 | 10:26 PM
3vil's Avatar
Mazda Misfit
possibly BAC valve
Old Mar 8, 2011 | 11:52 PM
what/where is the bac valve?
Old Mar 9, 2011 | 01:23 AM
3vil's Avatar
Mazda Misfit
well for starters, i see your car is an 87, is it turbo or NA? if it's an NA then this thing is your BAC valve (you can search on how to test/clean it)
i can't find a really good picture right now (i'm too lazy to go outside) but on an NA it's on the Dirver's side of the Dynamic Chamber (assuming you have a left hand drive car) it has a green plug going to it.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
firzen
Sep 15, 2015 12:04 PM
rx7shirley
Sep 2, 2015 02:11 PM
