Turbo motor swap/ motor and tranny swap
Old Mar 8, 2011 | 06:27 PM
26rx786's Avatar
I have been researching a little but cannot get the answer I'm looking for.
I have an '86 rx7 NA and I would like to go turbo. Would I be able to drop a TII motor in and then rebuild the NA tranny to handle more power or should I swap both in? Thanks
Old Mar 8, 2011 | 07:05 PM
-Crash-'s Avatar
89FC
Umm what? Not sure what you are asking here? If you swap to a TII motor, then why would you build the N/A?
And how would you "swap both in"?
Old Mar 8, 2011 | 07:07 PM
SpeedOfLife's Avatar
rotors excite me
Most likely it'll be cheaper and easier to swap the turbo trans in, too. You'll want to consider the turbo differential, too. Search, there's a lot of info on these swaps.
Old Mar 8, 2011 | 07:08 PM
jjcobm's Avatar
Are you experienced?
First question: Yes
Second Question: It's up to you.
Old Mar 8, 2011 | 08:39 PM
FelixIsGod29X's Avatar
Manual Rack
Just so you know, this is the list to actually do the swap
***Keep the n/a harnesses***
S4 t2 long block
tranny (i wouldnt want to use the n/a tranny)
clutch
clutch slave
starter
driveshaft or custom shaft if keeping the crappy n/a rearend
rearend
t2 hood or front mount that ****
n332 ecu
n318 boost pressure sensor
n318 AFM
turbo fuel pump
turbo throttle cable or get tricky and make the n/a cable work
Thats the gist of it. Im always forgetting somethings.
Old Mar 9, 2011 | 08:54 PM
26rx786's Avatar
Thanks guys. I appreciate it , especially the parts list. It'll give me a good place to start
Old Mar 9, 2011 | 10:11 PM
RotaryRocket88's Avatar
Top Down, Boost Up
There are a number of threads in the archive. Links in the FAQ and in my sig.
Old Mar 10, 2011 | 12:52 AM
3vil's Avatar
Mazda Misfit
iirc aaron found the breaking point of the NA trans, it was somewhere around 350torque? i can't find the post by aaron right now (been drinking) but i'm sure someone will correct me
Old Mar 10, 2011 | 08:12 PM
killalot13601's Avatar
If you plan to run the factory turbocharger then a N/A transmission of good condition will do just fine. I actually prefer to run them because of the weight difference.
Turbo II transmissions use a larger flywheel. This comes in handy because you can stick with a disk type clutch and have the holding power of a Puck type N/A clutch. This makes the clutch more forgiving for street use.
There is a difference in gearing that you may want to review as well.
cristoDathird
28
May 30, 2019 08:47 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
