Power FC power fc and 1600 or 2000cc primarys?
Old Mar 7, 2011 | 10:51 PM
Rotor Nut.
how will the power fc fair with a set of id1600's or a set of id2000's? im thinking of switching over to e85 but i would like this bad boy to idle and have decent driveablitly.
Old Mar 7, 2011 | 11:03 PM
cewrx7r1's Avatar
Eye In The Sky
Stock 550 and ID725 idle well on gas. Larger do not.
E85 will require about 35% more flow capacity then gas.
Using grade school math with the above injectors, we now have a range
of 742.5 to 978.75.
This make your ID1600/2000 too large for primaries.
Use the 725s or 1000s.
Old Mar 10, 2011 | 12:15 PM
thewird's Avatar
I know the ID1000's work well in the primaries for pump gas as its what I use (by well I mean acceptable, you still have a add a touch of negative lag). You might be able to get away with the ID1600's with a lot of negative lag for E85. ID2000's will probably still run if done right but it might be pushing it. Only one way to find out as I'm sure it hasn't been tested yet :P. Maybe run the ID1000's but with higher fuel pressure or 4 x ID1600's as secondaries.
thewird
Old Mar 31, 2011 | 06:40 PM
the_glass_man's Avatar
Will u do me a kindness?
Another vote for the ID1000's for the primary position. It will be a lot easier to get your idle set.
Old Mar 31, 2011 | 06:50 PM
vosko's Avatar
Just Call Me Terminator!
i'm going 725/2000's soon
Old Mar 31, 2011 | 09:06 PM
ryan1's Avatar
Originally Posted by pluto
I actually have a rx7 here running 4 ID2000 inj on pump gas. It idles at 13.4:1 w/o any issues. This is on a haltech Platnium. NOTE to others, 4 x ID2000 won't work well on PFC due to the ECU limitations
Look at the e85 lessons learned thread, lots of the info you seek is in there.
Skeese
65
Mar 28, 2017 03:30 PM
Clacor
Aug 14, 2015 09:17 AM
