fuel pulsation damper: different kinds?
Old Jul 7, 2002 | 08:29 AM
DamonB's Avatar
I know the fpd can cause a lot of problems; namely making your car into a campfire. For everyone that has replaced a failed one I hear about how the plastic parts break down and then begin to leak. When I swapped motors recently I looked very closely at my fpd and mine is all metal with a metal fitting; no plastic on it at all.
Are the "new" replacement dampers of a new design and mine replaced already?
Old Jul 7, 2002 | 03:34 PM
GsrSol's Avatar
Z06 powered FD
If I remember correctly, the main part of it that leaks is the rubber in the top of it. After a while that rubber will become hard and crack, spitting fuel out the top. That's all I know.
Old Jul 7, 2002 | 03:52 PM
rx713bt's Avatar
Yup, that's how the FD ones leak. The rubber diaphram leaks from the top. I've seen about 3 of them leak that way.
-Jeff
cristoDathird
28
May 30, 2019 08:47 PM
Rotospectre
Mar 28, 2018 03:33 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
