Drifting Discuss Drifting and drifting techniques here.
Mazdaspeed vs kaaz vs tomei vs os giken 2 ways
Old Feb 16, 2011 | 10:44 AM
DR_Knight's Avatar
Looking to pick up a 2 way diff and saw theres a new mazdaspeed 2 way for sale ready to go for an alright price. Anybody with experience with them? Im guessing there not that aggressive and should save up for a kaaz tomei or evem an os giken unit. Any input?
Old Feb 16, 2011 | 11:13 AM
Digi7ech's Avatar
I break Diff mounts
Carbonetic/ DeftForce!
****'s bulletproof.
Old Feb 16, 2011 | 06:23 PM
TheGoldenSB's Avatar
Just weld your visous lsd its worth it!!
Old Feb 16, 2011 | 06:45 PM
DR_Knight's Avatar
Already went through a welded diff and like the feel of a 2 way. I would weld this for now but its a clutch type. Also if anybodys selling a 2 way shoot me a pm
Old Feb 17, 2011 | 02:08 PM
vortex`'s Avatar
Rotary for LIFE!
Mazdspeed 2way is just a re-badged KAAZ 2way. Clutch based LSD, mine looks solid and should be pretty good - but I won't be drifting with it, only circuit.
Old Feb 17, 2011 | 02:27 PM
Rx7dailydreamer's Avatar
mazdaspeed is the same as kaaz basicly. its your preference
Old Feb 17, 2011 | 05:00 PM
sunburn's Avatar
Mother****ing Wow
OS G is the ****...
the engagement is adjustable and you can go from 2-way to 1.5 if you want.
I love mine.
Old Feb 18, 2011 | 12:16 PM
DR_Knight's Avatar
did my research and im saving up for the os giken unit. Says its only for viscous diff models so Im guessing I have to use a s5 t2 diff for the stubaxles?
Old Feb 18, 2011 | 01:08 PM
sunburn's Avatar
Mother****ing Wow
Smart move... I promise you will love it and it is well worth the extra coin...
Look on their site and they give you part numbers on the stub shafts -I remember I had to switch mine.
Old Feb 19, 2011 | 09:28 PM
Dirt-McGirt's Avatar
I have 2 years of absoulute rape on my Tomei. **** locks harder than most diffs. There also a rebadged Kaaz i believe, but with a higher torque rating.
Old Mar 1, 2011 | 07:09 PM
DR_Knight's Avatar
Ugh so im back to deciding.
Ats deftforce vs osgiken. Anybody have experience with both?
Old Mar 1, 2011 | 07:10 PM
DR_Knight's Avatar
Is the extra 400 worth it?
Old Mar 1, 2011 | 07:34 PM
Digi7ech's Avatar
I break Diff mounts
Just a evaluation of the deftforce from my friend which use to drift a S13 and now has a LS FC.
::Written for S13 drivers::
Description
Considered the definitive "drifting" differential by many. This diff has the most aggressive lockup characteristics and the biggest clutch plates of all the diffs available.
- Type: 2 way clutch type
- Price: ~$1050
- Number of plates: 16
- Can be used in open diff case or VLSD diff case.
- Largest clutch plates out of all the diffs.
- Highest lock up rate. 93% lockup.
- Comes with bearings, gaskets, seals, and new ring gear bolts.
Pros
- Best damn diff for drifting. Period.
- Oil changes every 6 months.
- Super aggressive.
- Makes the car snappy and hold rediculous angles. Angles previously thought to only exist on the moon.
- Did I mention its the best thing ever?
Cons
- Price. Its expensive. Whatever I dont care. I like quality.
- Uses super special fluid thats expensive. I use Royal Purple cause I dont care.
- Its loud. Yeah so what. If you buy this diff you better expect it.
Driving Impressions
This diff was hand crafted by Satan himself. Now, dont get me wrong, I was skeptical at first when I bought it. Honestly could a different diff that has slightly bigger clutch plates, higher lockup rate, and a name like Deftforce really be better...?
**** YES IT CAN! I was amazed by this diff. I dare say its the best thing I've done to my car. The diff holds REDICULOUS angles and allows for the funnest and most aggressive transitions I have ever tried. The difference between this and other diffs is very noticable. I will never own any other diff ever again.
Old Mar 2, 2011 | 02:57 AM
vortex`'s Avatar
Rotary for LIFE!
Just get something and drift the **** out of it already
Old Mar 2, 2011 | 06:31 AM
4WDrift's Avatar
skookum
That description of the deftforce makes it sounds like it the best **** ever!
Old Mar 3, 2011 | 02:57 PM
DR_Knight's Avatar
Haha k deftforce it is. Just used the past few weeks deciding because ive been saving up those paychecks.
Old Mar 3, 2011 | 03:51 PM
FC_fan's Avatar
Sideways is the only way
I personally like the os giken for its adjustability between 2-way and 1.5 way. then again, I daily my car and like grip driving as well as drift duty so to each his own. I have never had any aftermarket lsd before though so I'm in the dark here listening to advice.
Old Apr 5, 2011 | 06:34 PM
Duster524's Avatar
**** YEA DAD
i live and die by my carbonetic 2-way! favorite mod done to the whip for sure!
Old Apr 17, 2011 | 01:54 AM
K!NCH's Avatar
Why 2way over a 1.5?
Old Apr 17, 2011 | 02:11 AM
ILoveJDM's Avatar
SSS-TUTUTU
drifting BRO
any other reason is just made up.
you want your wheels locked at virtually all times when drifting, so 2 way.
Old Apr 17, 2011 | 12:15 PM
Vell's Avatar
Not an absolut truth ... Anyway, 2 or 1.5 way is fine.
Old Apr 17, 2011 | 12:39 PM
K!NCH's Avatar
Originally Posted by ILoveJDM
drifting BRO
Right so then why do JTP, Mike Essa and Dave use 1.5ways?
Old Apr 17, 2011 | 01:08 PM
Indian's Avatar
It wasn't me!!
Old Apr 17, 2011 | 01:27 PM
ILoveJDM's Avatar
SSS-TUTUTU
Right so why do other drivers use 2 ways? Preference? Really no need to be a dummy about it.
Old Apr 17, 2011 | 01:47 PM
R-R-Rx7's Avatar
Rotor or no motor
im not reading all the posts. i used ATS, mazdaspeed and OS giken. BY FAR OS giken is the best
