RX2 Struts and rear end.
Old Jan 29, 2011 | 02:59 PM
surem03's Avatar
ROTARY KING
So time has come to start buying all my parts for my 71 rx2. I wanna change the struts in the front, but don't know if any rx7 struts will fit ,with out doing any modification. I also want to put in a LSD rear end but don't know what donor car to get from. I read on a aussie forum that a rear end from a 82-83 gsl can work buy taking the pumpkin out and putting it on the stock rx2 rear end.
thanks in advance.
Old Jan 29, 2011 | 06:34 PM
OZZYINCALI's Avatar
Billy @ ReSpeed sells aluminum spacers that drop into you Rx2 struts so you can use 81-85 Tokico shocks. These spacers are about $40 and shocks you can get for about $120 shipped! the lsd pumpkin from a 81-83 gsl will bolt into your rx2 rear end. hope this helped
Note: the threaded collar that comes with the rx7 shocks will not match the rx2 strut threads. My car was fitted with konis that have threads in the shock so when I removed them to install the Rx7 Tokicos I had no way to secure the shock, so if you are removing the stock type shock keep the top collar. I had to tack weld the rx7 tokico collar to the Rx2 strut. This works but is not ideal.
Old Jan 29, 2011 | 07:29 PM
surem03's Avatar
ROTARY KING
Thanks!!!! Are the spacer for the front and rear shock the same?
Old Jan 30, 2011 | 02:53 AM
OZZYINCALI's Avatar
no spacer for the rear mate, we are all screwed when it comes to rear struts. i heard if you are going to stay at the stock height you can use a 99 Toyota 4runner front assembly in the rear of an Rx2. Dunno if it works, but who the hell wants to keep their car stock ride height anyway?
Old Jan 30, 2011 | 08:37 AM
surem03's Avatar
ROTARY KING
So what will be a good option for the rear? Am not trying to stay totally stock so it's doesn't really matter.
Old Jan 30, 2011 | 08:47 AM
73rx313b's Avatar
I actually own Rotaries
you can get a pair of Koni's for the rear from Classic Garage.com but there about $650 a pair and they only have a couple of pairs left....fyi
Old Jan 30, 2011 | 11:57 AM
P-nut's Avatar
Search function & form coilovers
Old Jan 30, 2011 | 02:30 PM
Siraniko's Avatar
RX for fun
people need to experiement
Old Jan 31, 2011 | 12:16 PM
OZZYINCALI's Avatar
CA
Very easy to say when you come from tinkering with Rx3 suspension set ups. The Rx2s self contained strut set up is a totally different animal then Rx3s leaf spring/shock configuration. Its a lot more expensive and critical then mixing and matching shocks at your auto parts store like you can do on an Rx3.
Old Jan 31, 2011 | 07:59 PM
surem03's Avatar
ROTARY KING
it's a pain in ***.....believe me
Old Jan 31, 2011 | 09:02 PM
Siraniko's Avatar
RX for fun
I say bull. if there is a will, there is a way. you guys are just afraid and don't want to spend the time or some cash to experiment period Think outside the box
Old Jan 31, 2011 | 10:09 PM
ultimatejay's Avatar
You can either buy the drop in function and form coilovers for 1800.00. That is for both front and rear.
Or for the fronts you can like mentioned above use the first gen inserts and use REspeeds spacer.
On the rear struts you have to get creative. You can buy a coilover strut assy that has an eyelet at both ends and it will bolt to the bottom in the stock location but the top you will have to make a mount for a single eyelet that would be very easy to do, but would involve welding. I also heard that a second gen rear strut assy will work with some modifications to the strut top. I contacted Koni and they said if you mail them your stock struts that they could make a new set too, so there's another option. I did not get prices though because I'm going to do end up doing it myself to save money.
Old Feb 12, 2011 | 12:12 PM
mrmasda's Avatar
SEcond gen shocks work 86-91. You just put your top hardware on them & they bolt right up. Mine have the coilovers on them from ground control. Go to RX-2 shock post by Jesuscookies for pictures in the club history
Old Feb 15, 2011 | 12:28 PM
surem03's Avatar
ROTARY KING
Thanks!!!
Old Feb 15, 2011 | 08:31 PM
OZZYINCALI's Avatar
fchoncho told me that the fc3s rears will make your rx2 ride really high and if you lower it the shocks will bottom out. Coilovers are the only shot and they may still be at their limit
Old Feb 16, 2011 | 06:31 AM
mazrx2man's Avatar
only the rear springs out of a second gen work no the strut it self..
Old Feb 16, 2011 | 02:46 PM
surem03's Avatar
ROTARY KING
So am still lost as to which struts to mount on the rear???????????????? The front i can use 1st gen front with spacer from REspeed. But the rear is where the issue is at right now.
Old Feb 21, 2011 | 12:05 PM
PureMdMa's Avatar
1 of 203 94 White PEP's
RE-Speed is working on a coilover solution for the front and rear of the 2 currently. He has the front done just needs to mock up the rear from a current set-up. Im planning on letting him borrow my car to use for the test mule.
Here is a link to the front. http://mrcmfg.com/catalog/product_in...roducts_id=434
Old Feb 22, 2011 | 07:09 PM
surem03's Avatar
ROTARY KING
Any idea on what the cost might be??????????????????????
sleepydogz
Oct 4, 2015 03:46 PM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
