rpf1 17 or 18
Old Jan 29, 2011 | 11:06 AM
razls1's Avatar
rpf1 17 or 18
undecided on 17inch or 18inch rims for fd. I really need as much sidewall as poss.so i was thinking the 17 with a 275/50 or 295/45 but I think the 18 would look better with a 275/45 18 but that would gve me a shorter sidewall..... Any pics would be great 17 vs 18. All opinons welcome
Old Jan 29, 2011 | 12:40 PM
ptrhahn's Avatar
What the heck would you want that kind of sidewall for?
The tallest you should run would be 275/40/17. That's already almost an inch taller than stock.
Old Jan 29, 2011 | 02:04 PM
razls1's Avatar
the car is a forged ls motor with a billet 76 gts turbo.... will be on the dyno in a few months power should be around 850-900 rwhp. The car needs a taller tire
Old Jan 29, 2011 | 03:11 PM
ptrhahn's Avatar
Well, you can't put anything that remotely matches up front, so it'll look ridiculous and probably rub over bumps. What are you trying to accomplish with the taller tire that wouldn't/couldn't be accomplished with a wider tire?
Old Jan 29, 2011 | 03:37 PM
razls1's Avatar
height is might when it comes to drag radials.
Old Jan 29, 2011 | 04:40 PM
silverTRD's Avatar
Time or Money, Pick one
is it primarily a track or street car? if its more a street car get a "normal" size tire whether you go 18 or 17 inch, then get a set of 16"drag wheels for when you go to the strip.
if its track only, then just keep the 16's on
