Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Anyone know of a computer program to interpret wb o2 sensor?
Old Jan 25, 2011 | 08:16 PM
DREYKO's Avatar
I "lost" my emissions....
I want to find a program I can use to read out Wideband o2 readings. I would prefer one that graphs like what they use in dynos.
So far as I can tell all I should need is a program a laptop a wb sensor and an adapter wire to connect it to the usb port and I can moniter the readings to adjust accordingly.
Any indo on programs or general set up of this would be awesome
Old Jan 25, 2011 | 08:22 PM
D Walker's Avatar
As I said elsewhere, any datalogger will graph a wideband signal, which wideband are you using?
Old Sep 26, 2011 | 04:23 PM
rotorbugg's Avatar
This is a good question. It could be possible; they have programs that will turn your pc into an ocilloscope using the mic/line input of your sound card. Not sure if that could measure DC though (as in O2 sensor) as the audio input may be capacitavely coupled. Also, you would probably want to log other attributes as well to make the charts useful. (At least rpm) Anyways I haven't searched the subject yet so I won't ask about data loggers, but I'd like to get something that's works off of a pc so I can use it for examining/tweaking the factory fuel injection.
