satellite antenna mounting
Old Jan 18, 2011 | 10:02 PM
justwcc's Avatar
I have an 89 gxl and want to install my Sirius tuner in the car, but I am having trouble figuring out where to mount the antenna. The car has a sun roof and if I install it anywhere behind it I believe that it will interfere with the sunroof operation as well as block the satellite signal. Also there is not enough room to mount it in front of the sunroof. does anyone have any suggestions or experience with issue because i need some advice.
Old Jan 22, 2011 | 10:36 PM
justwcc's Avatar
I decided to go ahead a try mounting it behind the sunroof and it worked out great. The sunroof did not hit the antenna when it was all the way back, but as expected it does cover the antenna so no satellite radio will be playing while the sunroof is open.
Old Jan 23, 2011 | 06:52 AM
MR_Rick's Avatar
Planning my come back
You should put it between the defroster vents on the dash. Take the little square piece off and run the wire that way.
freq
Sep 7, 2015 04:35 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
