20B-FD available subframes
Old Jan 18, 2011 | 02:38 AM
Rxmfn7's Avatar
Do a barrel roll!
Ive been searching for a while, but it seems like most of past links are dead. I may be in the market to buy a 20b subframe for my FD, and I was wondering what all was out there. I was originally planning on fabbing my own or just using Defined Autowork's mounts that place it on the stock subframe, but I was wondering if there was another possible option that would lower the engine down and further back. Im considering going dry-sump and will already be fabbing custom trans mounts and a driveshaft so none of that is a concern.
Old Jan 18, 2011 | 01:03 PM
RZMotorsports's Avatar
1000hp Quest
subframe
I have a company that still makes a subframe that its perfect for FD's that is the one i use in my car. Feel free to contact me if you need any other questions.
Old Jan 18, 2011 | 04:06 PM
t-von's Avatar
Rotor Head Extreme
If you want it moved back and down, just copy the one in my thread. You will have to do something about the LIM though.
Old Jan 18, 2011 | 06:49 PM
Rxmfn7's Avatar
Do a barrel roll!
^Mine will be N/A with ITBs, so I dont forsee clearance issues that you would run into with the stock intake setup. Ill check it out.
Old Jan 24, 2011 | 06:31 PM
doctorotor93's Avatar
we sell them but not for the move back mod. the plus with our product is you keep the stock shifter location and you don't have to hack your car up!
Old Jan 25, 2011 | 12:53 AM
jamespond24's Avatar
How much? How about the steer bump?
Old Jan 25, 2011 | 11:26 AM
Zero R's Avatar
Just in time to die
We make them for the typical location, if you can make it yourself and want to drop it down and back go that route it will but cheaper just more headache.
~S~
Old Jan 25, 2011 | 02:55 PM
Slevin_FD's Avatar
pissin' on pistons
T-Von , PM me about your subframe when you get a chance. or email me. zero.g.morotsports@gmail.com
Chris.
Old Jan 26, 2011 | 09:56 AM
rx7rcer09's Avatar
Sir Braps A lot
i know Logan at defined autoworks makes a custom 20B subframe using the existing stock FD subframe. i would give them a call hes real easy to work with.
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
