going from twin to single
Old Jan 16, 2011 | 04:47 AM
indio84's Avatar
OK I'm in the process of removing the twin setup but as we all know there are so many vacuum hoses that my head is spinning.
any i took a look at this thread https://www.rx7club.com/3rd-generation-specific-1993-2002-16/vacuum-diagrams-stock-simplified-sequential-non-sequential-single-turbo-749702/
is this the one to use for the single setup aswell?
and also does anyone have a picture or electric diagram for the harness, it's my understanding that there are some plugs that need to be removed that are not used any more when going single turbo?
any thread or info on this
thanks
Old Jan 16, 2011 | 10:36 AM
oo7arkman's Avatar
In the Garage
Couple single vac diagrams I found after searching the the single turbo forum. I used these as a guideline when going single.
https://www.rx7club.com/showthread.p...+turbo+harness <-- I found this with about 10seconds of searching as well. Please read carefully before you go hacking away. You may cause issues for yourself later if you do this improperly.
I also saw while searching you also asked these questions in the single turbo section. Please utilize the search function and post your questions once in the appropriate section.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
sinistersam
Sep 13, 2015 07:17 PM
