White smoke
Old Jan 14, 2011 | 01:08 PM
imitek's Avatar
imitek
Question White smoke
this is the problem
when i start the car up from cold the car runs fine as it starts to heat up to temp white smoke starts to come out the exhaust and it just gets worse and worse the longer i leave it running.
then i rev it and it starts to misfire slightly and the street is full of white smoke
any idea any 1
to me it smells like water mixed with normal exhaust fumes if that helps
Old Jan 14, 2011 | 01:14 PM
revhardallday's Avatar
Bang Bang!
coolant seal id have to say
Old Jan 14, 2011 | 01:20 PM
r074r'/ |\|00B
how's your coolant level?
Have you done a coolant pressure test?
Old Jan 14, 2011 | 08:13 PM
ThekidintheFD's Avatar
sounds like the coolant seals, do the champagne test or coolant pressure test to be sure.
Old Jan 15, 2011 | 10:14 AM
oo7arkman's Avatar
In the Garage
As mentioned above do a coolant pressure test. The champagne test works but is less definitive. Another quick test you can look at is when doing to champagne test, watch the coolant reservoir when you start the car, if coolant explodes out of the neck as you fire the car up you most likely have a bad coolant seal.
If the exhaust smells sweet and just keeps getting thicker white smoke, rejoice, you have a coolant leak and need a rebuild (its not worth getting upset, it is what it is...). Up-side is you can take this opportunity to get a very nice engine build and update any other things in the bay with new oem parts as you go. I had the same thing happen to me a little over a year ago.
Old Jan 15, 2011 | 10:48 AM
imitek's Avatar
imitek
thanks m8 and evry 1 els for input this forum is the most helpful i have joined
im gona take engine out when i have some more money
i may have clipped the water seal when building it last year but i never kept it running for long so never would have none till now the car has not been on the road yet
quick question for all what do you think of the following items
http://www.pineappleracing.com/cooli...estercspt.aspx
http://www.pineappleracing.com/hdwat...fdrews5re.aspx
my apex seals are new 2piece
new bearings
new eccentric shaft
1x new gear rear plate
1x rear plate
all new apex springs
new corner seals
so i only need the water seal kit and exhaust gasket
any recommendations
thanks guys
Old Jan 15, 2011 | 10:54 AM
imitek's Avatar
imitek
the coolent level is going down
i have not yet done a pressure test yet
im gona do the test once i take the engine out
on a bench something not right spark plugs are covers in water
i don't think it is a crack or corrosion in housings but well have to see ill keep update
Old Jan 15, 2011 | 11:14 AM
Bang Bang!
if coolant levels are dropping most likely its burning it out the exhaust especially as u said it blows out white smoke. good luck with it.
Old Jan 15, 2011 | 05:50 PM
oo7arkman's Avatar
In the Garage
The pineapple racing pressure tester is a good tool after building an engine. But not what you are after for the purpose of testing the engine before removing it to confirm a coolant leak. That tester should be available at your local auto parts store for rental or purchase at places like Sears or Harbor Freight.
I can recommend the Pineapple racing water seals. I know MANY individuals as well as professional engine builders use them in builds. They are one of the few non-oem items that I have seen most professional builders use. I am definitely NOT a professional engine builder. That being said, after all the research I did before building my engine I decided they were the best thing I could use for coolant seals. But that is just my opinion.
Correct if all of your other seals were just replaced they SHOULD be ok. I would most definitely check them over well, clearance them, and make sure I replace them in the same location I took them from.
You really need to make sure you know WHY the seal failed this early. Maybe it was due to incorrect assembly, but it could also be something else. Just look everything over and take it all apart carefully so the failure can be identified as well as justified.
Old Jan 16, 2011 | 06:28 AM
imitek's Avatar
imitek
i think it may have been incorrect assembly i built engine twice in 1 day due to i thort i may have put the oil springs on backwards
mabe in the rush i could have caught the water seal o well
round 3 lol
Old Jun 8, 2013 | 08:54 AM
imitek's Avatar
imitek
round 3 lol
if any one still interested in what happened basically i fukked up i put a rotor spiral spring in backwards and it killed the front plate looks like (sunflower) got a new rotor and front plate ready for round 3 lol
keep doing it till you get it right haa
at least i found the problem i caused ay
i will get some pics at some point
Old Jun 13, 2013 | 02:32 AM
Rotary Madman's Avatar
rebuild time!
Old Jun 13, 2013 | 10:47 AM
Tem120's Avatar
nice to know sucks that it happened but glad the car is running again
Old Jun 15, 2013 | 12:14 PM
imitek's Avatar
imitek
car getting striped
engine removed
front plate trashed
bits
engine build
Size:  87.3 KBhttp://i1199.photobucket.com/albums/...5062013288.jpg
http://i1199.photobucket.com/albums/...5062013289.jpg
http://i1199.photobucket.com/albums/...5062013292.jpg
http://i1199.photobucket.com/albums/...5062013290.jpg
i no my engine stand is awesome
Old Jul 28, 2013 | 07:02 AM
imitek's Avatar
imitek
got engine back in car and running again yeaaaaaaaaay
took a while i left the fuse box loom plug disconnected cranked it for few min then got it started
gona need a new waterpump she is squealing like a pig
rx7 start after rebuild - YouTube
Old Jul 29, 2013 | 12:06 PM
Tem120's Avatar
GREAT TO HEAR ! . thanks for posting the cause !
antman0408
Oct 5, 2015 04:33 PM
SpaceCadet_Alt3
Oct 1, 2015 11:35 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
