Air Bleeder Screw
Old Jul 4, 2002 | 01:57 PM
Node's Avatar
Air Bleeder Screw
Should I just order one, or should I just order one or two more for later on in my Rotary life, just so I have it on hand.
Which reminds me I need to get a small parts case to keep this stuff organized.
Mines stripped to all hell, and I'm gonna have to ghetto rig it to get it out. Any suggestions on how to remove a heavily stripped airbleed screw?
I was told to heat up a sharp screwdriver and hopefully that would make its own grooves, enough to get it out at least.
And is there anyplace cheaper to get this other than Mazdatrix? $4.15+S&H
Old Jul 4, 2002 | 02:03 PM
BlackRx7's Avatar
Daily Domestic Killer
if you can't decide wether to spend more and get more or less and get less then you need be somewhere else,
just get 2 hell maybe 3, unless you can't spend 15 bucks
Old Jul 4, 2002 | 10:00 PM
deadRX7Conv's Avatar
Opinions are like........
Do a search for easyout ez out screw extractor or remover. I know sears has one. Not sure if links work.
http://www.sears.com/sr/craftsman/wh...OOL&Tool_Id=14
http://www.brokentap.com/easy-outs.html
Old Jul 5, 2002 | 06:11 AM
HAILERS's Avatar
HAILERS
Where is the air bleeder screw? Maybe its too early in the morning for me, but that term isn't making a connection in my head.
Old Jul 5, 2002 | 09:21 AM
knight1976's Avatar
Cheaper? Man how cheap you want it?
Old Jul 5, 2002 | 10:45 AM
Icemark's Avatar
I am assuming it is the screw on the side of the series 4 rad. for purging air from the cooling system.
Node:
If the head is all stripped on a plastic screw like that, I would either drill it out, or heat a screw driver tip up red hot and let it melt in deep enough to have some grab and when it cools unscrew.
Like knight said; its a $5 part... I say get two (one for the purge, and one for the bottom of the rad) and replace them both.
Old Jul 5, 2002 | 11:33 AM
blu_gxl's Avatar
and i thought I was cheap!
Old Jul 5, 2002 | 12:54 PM
momar's Avatar
What I did was take a dremmel and just cut a slot for a screwdriver to fit in and it came out. Might work for you depending on how stripped it is.
Old Jul 8, 2002 | 10:46 PM
Node's Avatar
hmmm, I didn't realize there was two, well I notice there were in my FSM but it passed my head.
I've been braindead the past week.
risingsunroof82
22
Sep 22, 2015 01:20 PM
ZacMan
Sep 19, 2015 09:20 PM
Frisky Arab
Sep 4, 2015 06:17 PM
