I really really really need someone to teach me......
Old Jul 3, 2002 | 05:48 PM
I really really really need someone to teach me to disassemble the power window motor mechanism so that i can put my window up manually i know wha efveryhting is i just don tyknow how to get it up by hand some one please help im sick of m the inside of my car getting wet its ruining it
Old Jul 3, 2002 | 06:07 PM
Aaron Cake's Avatar
Engine, Not Motor
Remove the two bolts that hold the window to the regulator. Push window all the way up, and install a clamp inside the door to hold it tightly up.
Old Jul 3, 2002 | 06:11 PM
Explain man whatyou really mena by a clamp what kinda clampp and where?
Old Jul 3, 2002 | 06:30 PM
Aaron Cake's Avatar
Engine, Not Motor
Anything that will fit...Some kind of small C clamp will probably work. Just to hold the window up temporarily...You could also shim with a piece of wood as well.
Old Jul 3, 2002 | 06:37 PM
No i have nohting thats small enough ineed antioher option on dissaembling the cirle that holds hte beads
Old Jul 3, 2002 | 06:48 PM
Aaron Cake's Avatar
Engine, Not Motor
Disassembly isn't an option if I am picturing the regulator properly in my mind...Have you tried connecting 12V directly to the motor to see if you can move the window? It may just be your switches that are bad.
Otherwise, you have no choice but to use a small clamp (check a hardware store) or replace the regulator.
Old Jul 3, 2002 | 07:39 PM
my dad fixed it my motor had high resitnace it was taost my dad been a mechainc for 28 year hes fixed it by dissasembling it
izzolaw
Sep 28, 2015 06:03 AM
gabescanlon
Sep 14, 2015 12:03 PM
Rx7marine
Power FC Forum
Aug 27, 2015 09:49 PM
SWAT81
Sep 8, 2003 01:12 AM
