Thermoswitch FD vs. FC, an arguement
Old Dec 21, 2010 | 10:08 PM
ttmott's Avatar
I question the need and benefit to perform the long heralded modification to remove the FD thermoswitch and replace with the FC thermoswitch.
For this argument we need to assume the cooling fan system is in the factory configuration and the engine cooling system is operating properly.
Cooling fan operation 101:
The fan system has three speeds in which the speed selection depends upon the engine’s demand for cooling. There are three elements that demand the fans to operate: ECM, AC, and Water Temperature Thermoswitch. Also there was a Mazda recall that added a fan off delay circuit to resolve an underhood temperature problem but we won’t go into that here…
The fans have three separate motor winding taps whereas as voltage is applied via relays to consecutive (in any order) taps the fan speed increases.
The fans can be turned to LOW speed by any ONE of the ECM, AC or Thermoswitch actuating the respective relay(s). Relays 2 and 4 are operated by the ECM, relay 1 by the AC and relay 3 by the water thermoswitch. The ECM uses two relays for fault tolerance (they are redundant).
The fans can be turned to MEDIUM speed by any TWO of the ECM, AC or Thermoswitch closing the appropriate relays.
The fans can be turned to HIGH speed by all THREE (ECM, AC, and Thermoswitch) closing all of the relays.
So typically normal engine cooling is managed by the ECM based upon input from the water thermosenser (not the thermoswitch).
The thermoswitch provides a couple of features: One being the higher fan speed when the sensor temperature threshold is triggered and the other is a redundant cooling means should the ECM relays or wiring fail (highly unlikely). All the relay circuits are fed from the same set of fuses (coils off the 15A meter fuse and contacts off the 60A cooling fan fuse).
ECM demanded cooling is on at (if I remember) 90C (194F). I now have a PFC and have this temperature set a little lower.
AC is on whenever the AC panel fan switch is any speed but off and the AC button is depressed.
FD Thermoswitch is on when engine water temperature reaches 108C (226F). FC thermoswitch is triggered at 95C (203F). The Miata thermoswitch is commonly used also but it’s set points overlap the ECM demand and will cause short term speed cycling.
In summary the Thermoswitch is only needed if the ECM cannot manage the engine cooling.
The various threads and posting in this forum seem to point that the thermoswitch change from FD to FC will lower the operating temperature of the engine. The only thing the lower temperature FC thermoswitch will do is trigger the higher speed fan setting if the engine is threatened by overtemperature. Again, nominal temperature control is managed by the ECM.
Now I have the FC thermoswitch installed; it’s one of the first things I did when I got the car. Would I do it again? No, unless the FD thermoswitch failed and I had to replace it. Some say that the mod relieves engine heat soak but again the engine needs to be boarderline overtemp for the switch to set the next higher fan speed. If I was worried about that I would bridge relay coils together for relays 2, 3, and 4 and always have a minimum of medium fan speed. AC on in this scenario would set the fan speed, obviously, to high.
Old Dec 21, 2010 | 10:22 PM
Sgtblue's Avatar
Urban Combat Vet
Originally Posted by ttmott
FD Thermoswitch is on when engine water temperature reaches 108C (236F). FC thermoswitch is triggered at 105C (221F). The Miata thermoswitch is commonly used also but it’s set points overlap the ECM demand and will cause short term speed cycling.
I"m not sure I'm catching all your points, but a couple of corrections.....
108 C = 226 F. And the S5 FC thermoswitch triggers at 95 C. (203 F.) The Miata switch was also 95 C. but was abandoned when it was learned the FC switch used the same connector as the OEM FD switch.
I can't give you a reference, but IIRC, most experienced opinions hold that coolant seal degradation starts around 115 C. ( 240 F.) Speaking only for myself, I never installed it thinking it would make my car run cooler by itself. The FC switch simply provides a bit more cushion.
Old Dec 22, 2010 | 08:59 AM
neit_jnf's Avatar
which one triggers the fans to stay on for 10min after shut down the thermosensor or the thermoswitch?
Old Dec 22, 2010 | 09:36 AM
rotaryinspired's Avatar
If you doubt it remove it from your car and tell us how the temps are in florida. In the nice warm summers in OK I'll keep the FC thermoswitch as I have had several cars both ways and it runs cooler and the fans stay on longer after shut down. Both good things IMO.
Old Dec 22, 2010 | 09:56 AM
ttmott's Avatar
The ECM does via signal to the fan relays 2 and 4 based upon the thermosensor. The little black box that patches into the harness behind the ECM evaluates ECM commanded fan on time and if the fans were on X amount of time before key switch was turned off the fans will remain on at low speed. Thermoswitch has nothing to do with this function.
Old Dec 22, 2010 | 10:38 AM
arghx's Avatar
rotorhead
105C
correct
the thermostat begins to open at 82C and opens fully at 95C. the series 5 FC thermoswitch that everybody uses triggers at 97C. I can look up the page in the series 5 service manual which explains this.
well the factory computer activates the fans at 105C, which is uncomfortably high for many people
The thermostat opens at 82C and opens fully at 95C. Just about every Mazda rotary engine has a thermostat with these opening temperatures.
an understandable perspective considering that you forgot the factory computer triggers the fans at 105C. Considering this is the factory calibration, many FD's have gone many many thousands of miles like this and have been fine. It still doesn't leave much room for error though and it makes a lot of people (including myself) uncomfortable.
fan control module comes on if the thermoswitch has been active for two minutes prior to shutdown. if the thermoswitch is lower temperature then the fans will be more likely to stay on when the engine is cut off. The Rx-8 uses a similar logic but dispenses with the thermoswitch, although it does have an actual engine compartment temperature sensor.
Old Dec 22, 2010 | 11:12 AM
moconnor's Avatar
As others have stated, the real number is a sky-high 105C, which I think makes your entire argument moot.
Beyond possibly reduced emissions, I am not sure there is any advantage to running at 105C vs. 90C - and certainly a lot of disadvantages.
rgordon1979
40
Mar 15, 2022 12:04 PM
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
HDA
Nov 3, 2015 03:49 PM
GKW
Sep 28, 2015 04:34 PM
