Re-painting my interior plastics: Round 2.
Old Dec 14, 2010 | 04:12 PM
theorie's Avatar
AponOUT!?
I am one to learn from my mistakes, and with that I decided to re-surface my interior plastics a second time. The first time I painted them, I only used Krylon Fusion, which apparently is more of a primer/dye than an actual paint. Naturally, that left a finish that showed nearly every imperfection in the prep job, which I unfortunately didn't notice until after the parts were re-installed in the car.
Round 2:
To paint the parts this time, I first used Krylon Fusion Satin Black as a primer. I have used this paint in the past when working with plastics, and it works very well as an undercoat because it is designed specifically to bond to the surface of plastics. This is where I stopped last time, at the Krylon Fusion coat.
This time, however, I decided to then coat the pieces with Rustoleum 2X Coverage Satin in Canyon Black. I intentionally sprayed the pieces from a further distance that normal (from a distance of about 3-feet) which resulted in a nice, even semi-textured surface, similar to the '94+ surface. After about 5 coats, I left the parts to dry overnight before reinstalling everything.
Old Dec 14, 2010 | 04:13 PM
theorie's Avatar
AponOUT!?
Installed pics:
Cheers.
Old Dec 14, 2010 | 05:19 PM
MissionRx7's Avatar
It looks great!
Old Dec 14, 2010 | 08:09 PM
staticguitar313's Avatar
R.I.P. Icemark
Good work man!
Old Dec 16, 2010 | 08:13 PM
cesarx7's Avatar
The Dirty Mexican
Looks great! Thanks for the tips!
Old Dec 16, 2010 | 08:32 PM
prrex4ever's Avatar
Now What?
Looks great, maybe someday I'll get around to doing mine.
Old Dec 16, 2010 | 08:39 PM
wjk0817's Avatar
DD
very nice, looks cleeeeen
Old Dec 17, 2010 | 09:04 AM
TwinCharged RX7's Avatar
Built Not Bought
Top Answer: 1
Hey Tom, looks great. Did you use just the spray can, or did you use a spray can and then add on the little plastic trigger mechanism (about $3.00) to turn it into more of a spray gun?
I found that its much easier to spray an even coat just because its easier to turn on the spray and you can hold it like a conventional spray gun. It also saves your pointer finger some pain if doing it for a long period of time.
For anyone else attempting this, get this and thank me after haha.
Old Dec 17, 2010 | 11:59 AM
estevan62274's Avatar
#garageguybuild
Veteran: Air Force
Looks great!
Very clean!
Old Dec 17, 2010 | 12:51 PM
Narfle's Avatar
Rx7 Wagon
Looks very good. Please keep us advised re: durability.
Old Dec 17, 2010 | 06:05 PM
theorie's Avatar
AponOUT!?
ah actually i've never been a fan of those adapters. if i'm going to rattle-can something, i like to do it with the standard push-down spray cap. i do a lot of spray painting, so i've got my technique down.
Old Jan 24, 2011 | 07:17 AM
r074r'/ |\|00B
subscribed, thanks!
Old Feb 3, 2011 | 05:50 PM
NeilBH's Avatar
That looks great. I just finished my interior plastics as well using the Bumper Coating spray that was mentioned in another thread. Turned out great also and is a near perfect match to how it came from the factory. It is definately worth doing since so many interiors are so beat up, just make sure to take your time with sanding and using goof off to rub the rubberized coating off if you have a 93 model.
Old Jan 11, 2012 | 03:17 AM
gt45r's Avatar
great post
Old Mar 25, 2012 | 07:13 AM
jeremyferguson4444's Avatar
It's been a year and a half....how's it holding up?? chipping, fading, etc....
Now that my windows are tinted and my interior is somewhat protected I've got some painting to do myself....
Old Mar 27, 2012 | 09:52 PM
diehardrotary's Avatar
yea that look really good.i think I'm gona do that instead if buying all new interior pieces
Old Apr 11, 2012 | 07:05 PM
MazdaManInTraining56's Avatar
Wow great info
