Rotor Measurements
Old Dec 11, 2010 | 09:58 PM
Donovan N.'s Avatar
Rotor Measurements
OK, so after seeing the E&J billet rotors and Mazdatrix Billet rotor, I have been kicking the idea around in my head to make my own set and was hoping some of you could help me out with the measurements.
I also have a question regarding Rotor radius measurements, in the link attached here:http://rotarynews.com/node/view/1050 , it talks about "R prime = R+a", would "R" be measurement "J" in my drawing? and would "a" be the apex seal stick-out from the rotor face?
Required Measurements
A= Rotor bearing Journel (Not the bearing I.D.)
B= Rotor Gear Journel
C= Inner Oil Seal Groove I.D.
D= Inner Oil seal Groove O.D.
E= Outer Oil Seal Groove I.D.
F= Outer Oil Seal Groove O.D.
G= Distance Between Rotor Face and Outside of Side Seal Groove
H= Distance Between Center of Bearing Journel and Bottom of Apex Seal Groove
I= Distance Between Center of Bearing Journel and Center of Corner Seal Groove
J= Distance between Center of Bearing Journel and Rotor Apex
K= Depth of Rotor Gear Journel
L= Depth of Inner Oil Seal Groove
M= Depth of Outer Oil Seal Groove
N= Depth of Side Seal Groove
O= Depth of Corner Seal Groove
Well that sould be all the measurements I would need, any help you guys can offer would be greatly appreciated.
Old Dec 11, 2010 | 10:04 PM
D Walker's Avatar
I would be somewhat concerned with material growth and the tolerances required, as these dimensions and tolerances may only be discovered after a fair amount of testing.
Old Dec 11, 2010 | 10:11 PM
Donovan N.'s Avatar
I know I was going to look into the thermal expansion rates and all that but right now this would be more of a time killing exercise than anything else.
Old Dec 12, 2010 | 08:48 AM
sen2two's Avatar
Rx2 > FD
This has been tried a few times, no one is going to give up the measurements to you. Really, not to be an ***, but if you have the skill to make a rotor, you have plenty of know how to take some measurements and lay one out.
Are you a machinist? Have a CNC?
Old Dec 12, 2010 | 03:56 PM
Donovan N.'s Avatar
yes, but I don't have any rotors laying around to take measurements from, I was going to use something called e-machineshop to draw it up
Bauer778
Nov 4, 2015 04:42 PM
risingsunroof82
Sep 9, 2015 08:06 PM
dillrx7
Sep 7, 2015 09:38 AM
