steering rack Bush size
Old Dec 9, 2010 | 12:54 PM
pietrino's Avatar
Italian Rider
Hi,
The mecchanick said that it dasen't fit.
I guess is the correct one, is the PowerFlex PRF 36-306
i putt a pics that show you my dimension.
Please anyone can check if has the same size?
Thanks
Pietro
Attached Thumbnails steering rack Bush size-img_3497.jpg   steering rack Bush size-img_3496.jpg
Old Dec 10, 2010 | 10:42 AM
gracer7-rx7's Avatar
needs more track time
Looks correct. Where exactly didn't it fit? Was it the internal diameter or something else?
Old Dec 11, 2010 | 04:12 PM
pietrino's Avatar
Italian Rider
the internal diameter is too small and dosen't close at all.
Thanks for reply.
You think that the measurement are correct?
May be the meccanic mounted in a different place?
Old Dec 11, 2010 | 11:21 PM
The general shape looked OK. Not sure about exact measurements. I sold mine to CrisyRX7. Maybe try PM'ing him to see if he can compare to the ones I sold him - If he hasn't installed them yet.
Good luck.
Old Dec 12, 2010 | 07:45 PM
pietrino's Avatar
Italian Rider
thanks
Old Dec 12, 2010 | 08:10 PM
pietrino's Avatar
Italian Rider
Good luck.
Thanks for the help, i dont find the user CrisyRX7, sure about the name?
Old Dec 13, 2010 | 10:48 AM
Sorry mis spelled
crispyrx7
https://www.rx7club.com/members/crispyrx7-1910/
Old Dec 14, 2010 | 11:11 AM
CrispyRX7's Avatar
Polishing Fiend
Hey guys, I'll pull them out of my to-be-mounted box of parts and take a measurement for you.
Is it possible you have mounts for a second generation RX7 rack? I'm not seeing anything that specifies a year.
Regards,
Crispy
Old Dec 14, 2010 | 11:45 AM
pietrino's Avatar
Italian Rider
thanks for help, really appreciated
the order was made for RX7 FD 3° generation, the code PRF 36-306 is correct accordint to powerflex catalouge.
Waiting for You :-)
Old Dec 14, 2010 | 06:49 PM
CrispyRX7's Avatar
Polishing Fiend
here ya go.
HTH,
Crispy
Attached Thumbnails steering rack Bush size-rackbushings1.jpg   steering rack Bush size-rackbushings2.jpg
Old Dec 16, 2010 | 03:00 PM
pietrino's Avatar
Italian Rider
Thank you very much.
It's looks like it is 8,3 cm, mine is 8,0 but i took measurement with the ring closed so may be the 2 mm different is due to this.
I will go on monday to see if is possible to mount, probably is a mistake of the meccanic
You whese really helpfull.
Thanks
rotor_veux
Sep 3, 2015 07:10 PM
REsuper7
Aug 31, 2015 09:19 AM
