OE 3rd gen wheel plus sizing
Old Jul 2, 2002 | 09:09 PM
amp's Avatar
amp
old yella
OE wheels 16x8 16lbs with 50mm offset aluminum...correct?
Any thoughts on widening it to 16x9...came across a pair i can use and a shop that has the experience...offset ?
Old Jul 3, 2002 | 07:47 AM
SleepR1's Avatar
I've often thought about that some time in the past...a 9-inch wide stocker would work supremely well with a 245/45-16, and you'd keep the wheel weight down under 17-lbs or so...a 45-mm offset should work. The tricky part is keeping the rear wheel's inboard rim lip away from the rear trailing arm.
Old Jul 5, 2002 | 07:24 AM
amp's Avatar
amp
old yella
actually 245/45/16 already works well with the stockers....
Old Jul 5, 2002 | 09:53 AM
SleepR1's Avatar
The 9 x 16 rim would provide supremely better sidewall support for a 245/45-16 tire. An 8-inch rim compresses the tire sidewall too much and you can see the sidewalls "bulging" away from the rim...
Besides if you think a 245/45-16 already works well on the 8-inch wide rim, why bother with fabbing a 9 x 16? There are no 16-inch tire sizes that are wider than 245/45-16?
Old Jul 5, 2002 | 10:58 AM
djantlive's Avatar
Although 245/45-16 fits on a 8" wide stock rim, I think it doesn't utilize the full tire surface like the 9" can. I think... Can anyone confirm?
Old Jul 5, 2002 | 11:00 AM
amp's Avatar
amp
old yella
yep...the tires with the 245s i speak of runs toyo proxes t1s which has stiff sidewalls...no bulging as far as i can tell
....Besides if you think a 245/45-16 already works well on the 8-inch wide rim, why bother with fabbing a 9 x 16? There are no 16-inch tire sizes that are wider than 245/45-16?
yep...i was lookin to use the 16x9s for competition tires
Old Jul 5, 2002 | 02:07 PM
SleepR1's Avatar
The 9 x 16s would be ideal with 245/45-16 Hoosier R3S03s!
Old Jul 5, 2002 | 10:49 PM
ptrhahn's Avatar
Khumo makes a 265/45/16 which would work on a 16 x 9" wheel. The problem would be finding such a wheel cheaply. You'd probably have to go modular, then you'd be better off just buying some cheap SSR 17".
I've looked into wheel widening, and it can be done. Weakens the wheel approx. 20%. Also, you can only add to the inside of the wheel, so the offset of the wheel would increase quite a bit. With the stockers, you likely have to run spacers to keep it off the trailing arms. By the time you dis all THAT, might as well get cheap 17's again.
FYI, you CAN get 16 x 8.5" wide Kosei K1s, which are light, cheap and heat treated (fairly strong.)
Old Jul 5, 2002 | 11:21 PM
SleepR1's Avatar
Yep, I used the 8.5 x 16 Koseis last season...$169 each...worked very well with 245/45-16 Hoosier R3S03s Each wheel/tire weighed <35 lbs. The wheel weighed 16 lbs.
Old Aug 17, 2002 | 09:49 PM
87GTR's Avatar
do they make 15 X 8 or 15 X 8.5 kosieis that is light weight?
Old Aug 18, 2002 | 12:10 PM
SleepR1's Avatar
Nope, the Kosei K1 Racings only come in 7 x 15s
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
