Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
1jz vs 1uz
Old Dec 7, 2010 | 12:54 AM
JTO's Avatar
JTO
1jz vs 1uz
so im starting to plan out my swap and im kinda down to 2 motors 1jz or 1uz i plan on drifting the car what is the preferd one some first hand exp is welcome iv searched but just really havent got any real good details thanks in advance
Old Dec 7, 2010 | 06:49 AM
Bwek's Avatar
High Comp Booster
Well you're definately searching the wrong forum for info on these motors lol
1jz wayyyyyyyy more support to make power and cheaper to make big power
1uzfe very very cheap to buy the engine itself, you will need a special bellhousing or adaptor plate for a 5spd transmission, more expensive to build for power (4 cams, 8 pistons etc)
they will need modified wiring or a standalone, custom driveshaft, custom rad, custom mounts, custom fuel, custom intercooler and the list goes on
Old Dec 7, 2010 | 09:32 AM
stevensimon's Avatar
both the 1j and 1uz will need "modified wiring or a standalone, custom driveshaft, custom rad, custom mounts, custom fuel, custom intercooler and the list goes on"..
personally i love my 1uz lexus and the way it sounds on the revv limiter. and a lot of people are pulling their jz for the uz motor too. it may be more expensive to modify but they handle boost well. my friend just dynoed a hair under 350hp on his 230k mile LS400 with a cheapie 1000$ single turbo budget. no fuel mods, no computer mods no nothing. just slapped it on and went.
Old Dec 7, 2010 | 09:36 AM
dpf22's Avatar
with the 1uz you have a lighter motor and start with a better torque curve.
Old Dec 7, 2010 | 09:40 AM
JTO's Avatar
JTO
i know im gonna half to do alot of custom work im just wondering more on power because when i was looking at specs they looked real close on paper but i was wondering more on a first hand exp how they are because to me whats the internet is not always true and im also wondering about the aftermarket support
Old Dec 7, 2010 | 10:28 AM
rotary-guy's Avatar
2jz'd fc
Seeing how your just wanting to drift go with the 1jz, slap a single on it and your good to go cause honestly your not goin to need more than 300 to 350, hell leave you can even leave to stock twins and run a bit more boost and rip it up.
Old Dec 7, 2010 | 10:30 AM
rotary-guy's Avatar
2jz'd fc
Originally Posted by rotary-guy
Seeing how your just wanting to drift go with the 1jz, slap a single on it and your good to go cause honestly your not goin to need more than 300 to 350, hell you can even leave to stock twins and run a bit more boost and rip it up.
Fixed my sentence
Old Dec 10, 2010 | 11:06 AM
dpf22's Avatar
Just the 1jz motor and transmission with computer cost more than my entire 1uzfe swap lol.
Old Dec 10, 2010 | 02:18 PM
rotary-guy's Avatar
2jz'd fc
If you know where to look the swap can be found for less than 1600
Old Dec 11, 2010 | 12:09 AM
dpf22's Avatar
got my swap running for about $2k
Old Dec 11, 2010 | 02:09 PM
NoPistons!'s Avatar
Tango Down
The price of the 1jz swap alone turned me off of it and i went a different route. I'm a drifter, i'm on a budget and i just wanna get **** done so if it were me, i'd just do a 1uz. I had a hard time finding one nearby that i could get for a fair fetch and the r154 conversion kinda had me scratching my head second guessing wanting to do it but I WOULD HAVE done it if i could have sourced one quickly.
I just had to pull the trigger on a swap and invest money in it before the new year or i'd never get it done and lose interest in my car.
1uz all the way man.
1j's are cool as ****, make nasty power, sound nasty and are just legit but the 1uz is the path less traveled and i'm all for that.
Old Dec 11, 2010 | 02:57 PM
Spirit-RE's Avatar
1uzfe ftw.
Old Dec 11, 2010 | 11:39 PM
JTO's Avatar
JTO
i know there both great motors and i know they both make great power any of you know what factory internals can hold hp wise for the 1uz im kinda leaning towards a 1uz but i have found 1j full swap for 2k to my house
Old Dec 11, 2010 | 11:46 PM
Jobro's Avatar
SAE Junkie
I'm involved in a 1jz-gte vvti (chaser jzx100) build at the moment.
So far we have a 60-1 and a manifold and a wastegate and a piggyback for the stock computer.
I will report back with results. This car made 193rwhp (genuine) through the auto, only mods being 3" pod filter and a incredibly BAD cat back exhaust (hks brand LOL).
Short term goal is starting at 0.8bar boost. Then rising it to 1.0-1.1 bar after a month or so. Long term goal is probably 1.7bar boost, cams etc etc.
Work will begin on that car in about 40 days
Old Dec 12, 2010 | 12:28 PM
dpf22's Avatar
I've seen 500 on the stock internals for the '94 and earlier 1uzfe. They have only 10:1 compression and larger rods. Mine is a '95 which has thinner rods and 10.4:1 compression. We'll see how things go. Won't be my first high compression turbo tune. Did a 3.8 Mivec v6 from an eclipse gt which has 10.5:1 on a 62-1 turbo to about 12 psi tune last summer. Talk about beastial!
Azevedo
26
Mar 1, 2019 09:19 PM
rx7ali
Dec 12, 2015 06:00 PM
ehime
16
Feb 16, 2011 12:36 AM
reaper60606@aol.com
Jan 23, 2009 05:50 PM
