whats a good hooking tire for stock fd rims
Old Jul 2, 2002 | 05:52 PM
93redFD's Avatar
Anybody know of a good hooking tire for the stock fd rims??? I thought about drag radials but how long does radials last??? I really think the factory tire size is ugly as hell, I want a smaller tire(not to small tho).. anybody have a suggestion???
Old Jul 2, 2002 | 10:56 PM
what are you after traction? If so, go for the Nitto555r's for drag race. For auto-x or road race use S03's or AVS sports. As with all high performance tires a lot of factors can contribute to the longetivity of the tires. The type of driving involved, the way you drive, and also the type of driving conditions.
Old Jul 3, 2002 | 01:44 PM
gnx7's Avatar
I have Nitto 555R 245/50/16's for the drags and have cut a best of a 1.71 60ft with them after about 3K miles of hard driving on them. When they were brand new the best I could achieve was a 1.78 60ft! They should last about 8-10K miles if you don't do major burnouts/donuts when not at the track. They are ok in the rain also and handle good for a drag radial. Any other form of drag radial (BFG DR's, ET Streets) handles poorly, is scary in a high speed turn, and in the rain is downright dangerous. Get the Nitto DR's if you do a lot of straightline racing.
I have S-03's for the street and they handle killer.... but I can't get better than a 2.1 60ft with them and they ice skate thru 3rd gear as they just aren't a sticky drag tire.
Maybe just get 2 extra 3rd gen rims and have Drag Radials mounted on them for when you want to go out and rail.
What et's/mph are you achieving now? If you are fairly stock you probably don't need them. I've seen a 3rd gen on street tires run 12.2's@119mph which is good. On a drag radial this could've been mid 11's easily.
GNX7
Old Jul 3, 2002 | 03:30 PM
maxpesce's Avatar
Ex fd *****
for an fd 245/45-16 is slightly shorter than stock (225/50-16) and will fit on the stock rim.
I just got some Pirelli P-7000s I am real happy with.
otherwise
SEARCH !
this topic has many current threads!
Old Jul 3, 2002 | 10:03 PM
93redFD's Avatar
what tire should I put on the front???? btw how much are the nitto's ???
