What can be taken off?
Old Jul 2, 2002 | 04:34 PM
Hey guys, I've got my intake manifolds off my 90' GXL(well, in the process of removing them anyway...for porting ). My question is: what can I remove while I've got everything apart, and how do I go about removing these things (IE: things related to the removed parts, loose ends to tie up once somethign somes off)? I'm trying not spend much more money on the car (already did the rebuild thing with engine porting, exhuast/midpipe/presilencer, intake, working on intake porting, etc...), but I can spend some for blocking things off/rerouting things. Thanks for your help, and maybe this will be useful for someone else as well.
Old Jul 2, 2002 | 09:19 PM
Anyone?
Old Jul 2, 2002 | 09:42 PM
NZConvertible's Avatar
I'm a boost creep...
If you don't need to pass emission tests you can lose the air pump and air control valve. If you have no cat they're not much use anyway. Read this thread; the info's on my Turbo but the NA's are similar.
