Pic request... BBS LM 18x10 + 50?
Old Nov 30, 2010 | 11:22 AM
LS1Pariah's Avatar
I've got a chance to pickup a set of LM's in 18x9 +42 and 18x10 +50
the problem is, they're in transit from japan on a ship and inaccessible for photos. He just had a stock photo of lm's, but not the actual wheels. I'd just like to see them, to know if the lips are gonna be decent or not. Anyone out there have a set close to these specs? Thanks in advance.
Old Dec 2, 2010 | 09:09 AM
Those sizes will fit a stock-fendered FD nicely. Unfortunately if you're looking for a crazy lip, with those offsets you probably won't get it. I'm sure they'll still look great on the car though
Old Dec 2, 2010 | 11:28 PM
johgar's Avatar
Garage_Techno
These are the actual wheels 18"x9" +42 and 18"x10" +50 offset.
The 9" +42 on the bottom and the 10" +50 on the upper one.
Old Dec 3, 2010 | 01:35 AM
moosejaw's Avatar
i run a +40 offset
18 x 8.5 and 9.5
check my album for pics
Old Dec 3, 2010 | 07:50 AM
Flyweight's Avatar
FD3S
The sizes you mentioned will work well for an FD. The fronts may be tight with a +42 offset and might require a fender roll depending on suspension/ride height.
The only thing I would say is that the fender clearance will be very low up and be very high in the rear. This is only a cosmetic issue but if it bothers you you might want to through on a set of 5-7mm spacers in the rear so that you have similar fender clearance as the front.
As for tires I would run a 255/35 18 front and either a 265/35 (will probably have more stretch that the front again just a cosmetic issue), a 275/35 (tall overall diameter) or a 295/30 18 (wide but in spec for the rear) in the rear. I would run the 295/30 if you find a tire you like in that size with a 5mm spacer. This may require a fender roll.
Those are a beautiful set of wheels that I think work great on an FD. I really like FDs with appropriate style wheels and there is a reason why Spirit Rs came with BBS RGRs.
Old Dec 3, 2010 | 07:59 AM
ALPSTA's Avatar
Mission Impossible
A forum member here called Tayfun-Bathurst has BBS LMs in 19x8.5 and 19x9.5 (in black with red stripes). I know not exactly what you're asking for but might give you an idea.
Old Dec 3, 2010 | 11:27 AM
Brent Dalton's Avatar
Sua Sponte
Old Dec 13, 2010 | 10:17 PM
mdpalmer's Avatar
T O R Q U E!
Originally Posted by memphisraines82
^^ Beautiful!!!!
