Megasquirt VE table customizations?
Old Nov 13, 2010 | 11:16 PM
SCCA RX7 RACER's Avatar
Gen 2 Raced Hard NA 13B
If exporting a 12x12 table and modifying the values to enlarge the table, is there a possible way to import the table back and have a larger table? Currently the table gets imported but some values are skipped and the table remains as a 12x12 despite the program recognizes 16x16 but still remains as a 12x12 table. Would this hit any limitations on a MS1 chip and can the firmware handle larger tables without issue? Firmware build is 029q. Also is there any newer builds of firmware for the MS1 chip other than the 029q?
Old Nov 14, 2010 | 07:19 AM
muythaibxr's Avatar
MegaSquirt Mod
The MS1 does not support anything higher than 12x12.
What problem are you hqving that makes you think you need a bigger table.
Ken
Coochas
44
Nov 5, 2019 11:08 PM
joel(PA)
Oct 4, 2015 06:07 PM
edgars95rx7
Link Vi-PEC
Oct 1, 2015 01:59 PM
