flywheel selection?
Old Jul 1, 2002 | 09:13 PM
machinehead's Avatar
kortez
flywheel selection?
Hello all. I currently am running a 12lb flywheel with the centerforce clutch. I am out growing the clutch so I am swithcing to the stronger RPS 6 puck. Any racing I do is at the drag strip and I am wondering if I should go back to the stock flywheel to help with the launching or if I should keep the lightwieght flywheel.
Thanks,
Cliff
Old Jul 2, 2002 | 12:45 AM
spyfish007's Avatar
Yellow Dragon is no more
I'd go back to the stock flywheel. That flywheel is heavier and you will get better 60 ft times with it.
Old Jul 2, 2002 | 01:51 PM
80-CU.IN.T's Avatar
True a heavier flywheel will help your launch times.
But if you want the best (IN MY OPINION) go tilton. I wish I did and will next time.
LongDuck
Oct 7, 2015 08:12 PM
