Power FC Need advice on which stock base map to start with??
Old Oct 10, 2010 | 12:47 PM
zeroG's Avatar
I just got around to getting and installing my PFC last week. I've read over every setup guide available here tons of times to make sure I got everything running properly. I still however have a very vague idea of actual tuning. I will be getting a professional tune, but I'm still waiting to install my intercooler and get a wideband first.
So here's my situation, I set everything up using the "newer" stock base map and lowered the values on the IGT at high boost as recommended. After running the car now for about a week, I can tell that my car is running rich because I can smell it at both idle and WOT. The "newer" base map is supposed to be good for an intercooler and high-flow/mid pipe which I do not have yet. So I'm assuming this is why I'm running rich. Again I'm just going by feel because I don't have an A/F meter yet to know for sure. Now my question is should I stay using the "newer" stock base map? Or should I switch to the "older" stock base map which is supposed to be only for an intake and catback? Or maybe something in between would be better?
My mods are on my sig, so you can evaluate from there.
For reference again, I do not have a datalogit or a/f meter. I just want to make sure that I don't potentially ruin anything before I can get a pro-tune.
I'd appreciate any help and thanks in advance!
Old Oct 10, 2010 | 02:08 PM
arghx's Avatar
rotorhead
Do you have a ported engine?
Old Oct 10, 2010 | 03:19 PM
zeroG's Avatar
Sorry I forgot to mention that, no it's not ported, it's stock
Old Oct 11, 2010 | 10:35 PM
arghx's Avatar
rotorhead
try whatever map makes your car run best in vacuum. don't boost it, limp it to a tuner. there are too many things that could be causing your car to run rich
Old Oct 12, 2010 | 05:52 PM
zeroG's Avatar
Alright I tried switching over to the "older" stock base map and it seems to run better. I didn't really notice any issues on the "newer" base map, just the rich smell. Now with the older base map only a couple of times in the last few days have I noticed the car smelling rich. The avg. knock levels I'm seeing are about 10-20 points lower with the older base map also. I Don't know if it really matters, but my max inj. duty was about 65% at WOT
Regardless I'll be sure to not boost until I get a proper tune. Thanks
Old Oct 12, 2010 | 05:58 PM
arghx's Avatar
rotorhead
so much for not boosting it huh
Old Oct 13, 2010 | 10:01 AM
zeroG's Avatar
lol, well that happened before I read your post
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
20B Forum
Aug 19, 2015 01:47 PM
