FD 18x8 +43 offset wheel ?
Old Jun 30, 2002 | 09:43 AM
RICKRX7's Avatar
Will a 18x8 +43 offset wheel w/225-45 zr17 tires rub the front end on a FD?
Thanks
Rick
Old Jun 30, 2002 | 12:22 PM
RICKRX7's Avatar
correction,17x8 not 18x8 wheel.
Old Jul 1, 2002 | 03:52 PM
ARD T2's Avatar
I would run 235/40/17's on that and you'll be dandy.
rishie
Don't go 225 when you can go wider.
Old Jul 1, 2002 | 04:07 PM
SleepR1's Avatar
I like 235/45-17...overall diameter is slightly taller than stock, but the load index is correct...
Old Jul 1, 2002 | 05:35 PM
RICKRX7's Avatar
I am trying to solve a tire rubbing problem on a friends FD. Would the larger diameter tire and offset cause the problem?
Thanks
Rick
rx7jocke
72
Jun 17, 2016 03:48 AM
