I have an FL car. Is that why I can't find the EGR valve?
Old Jun 29, 2002 | 09:58 PM
JONSKI's Avatar
5yr member, joined 2001
Old Jun 29, 2002 | 10:01 PM
turbojeff's Avatar
Do it right, do it once
All 93-94 cars have EGRs, only the 93 Cal and 94s have a switch that reports EGR function to the ECU.
Anyway it is either blocked off or you aren't looking in the right place. It is on the lower intake manifold right above the turbos, behind the aluminum y-pipe. There is a blue connector that will be plugged into it if it is setting a check engine light. If your car isn't a Cal or 94 then the connector should be unplugged.
Jeff
Old Jun 29, 2002 | 10:08 PM
R Xplicit's Avatar
if the is a JDM for some reason, it won't have one, otherwise, it has been removed and blocked. is there an air pump on it?
Old Jun 29, 2002 | 10:43 PM
JONSKI's Avatar
I must be blind or I haven't removed enough parts to even get a look at it.
I'm calling it a night. I just broke both nipples off my turbo pre-control solenoid.
Th0m4s
Feb 26, 2019 02:04 AM
elfking
Aug 19, 2015 09:48 PM
Junkee
Aug 15, 2015 01:57 PM
