Sponsored by: CARiD
turbo mods?
Old Jun 29, 2002 | 10:53 AM
diabolical1's Avatar
Question turbo mods?
hey ...
anyone out there know where to get stock turbos modified? specifically, a place that would be able to put ball bearings into a stock turbo (that obviously had none before)? also, thermal coatings and making bigger, more efficient oil passages?
see, i got the stock turbo modified, but i still have not put it in the car yet and i'm thinking ... i want this stuff done to it before i put it in.
thanks for any advice or direction
Old Jul 9, 2002 | 11:52 PM
Marine7599's Avatar
There are a lot of places to mod stock twins. M2 performance will do it but you will have to do a lot more to make up for the increase in power. You will need new injectors and ways to control it. Also putting ball bearings into and old turbo is not a good idea becuase of possible cracks in the old turbo.
Old Jul 10, 2002 | 12:00 AM
thanks, man ...
i had pretty much given up on ever getting an answer to my question ...
Old Aug 19, 2002 | 01:42 AM
dr.jones63's Avatar
It's a Hammer
I've seen these on E-Bay
http://cgi.ebay.com/ebaymotors/ws/eB...851057810&rd=1
ITEM DESCRIPTION: You are bidding on a 89-91 Mazda Turbo II Turbo that has been UPGRADED to a TO4 Garrett turbo. It has a .60 A/R compressor with a 3 inch inlet and a 2 inch outlet. Compressor wheel trim is 60. This turbo will bolt on directly to your stock manifold with NO MODS needed that's right NO MODS needed. This is a good way to modify your car without spending lots of $$$$ for a turbo due to the fact that it's a direct bolt on item. Turbo has new parts in it (seals, bearing, o-rings, compressor housing, etc.), and has zero miles on it after being built and never got put back on car. Turbo will spool fast because of the stock turbine housing that will recycle the exhaust faster. For questions (please ask before bidding) please send an e-mail to my business partner at gtkoni@yahoo.com
Old Aug 21, 2002 | 03:15 PM
youngteggo's Avatar
Try these guys they seem to have a very good thing going.
http://www.lourdsmusic.com/bnrsupercars/index.htm
cristoDathird
28
May 30, 2019 08:47 PM
Kyo
Apr 13, 2019 09:24 AM
rotor_veux
46
Jun 12, 2018 10:39 AM
Turblown
Aug 14, 2015 04:48 PM
