Power FC Datalogit - Can you change units?
Old Sep 20, 2010 | 05:08 PM
$lacker's Avatar
It would be a bit easier to follow if the vac/boost could be changed to log in psi and show in the tables that way
Is that possible?
Old Sep 20, 2010 | 07:11 PM
arghx's Avatar
rotorhead
no
and yes it's stupid
Old Sep 20, 2010 | 07:55 PM
$lacker's Avatar
Argh
They need to fix that in an update... should be fairly trivial programming-wise
Old Sep 21, 2010 | 04:13 PM
cewrx7r1's Avatar
Eye In The Sky
It is a Japanense product for a Japanese car.
If you do not like it, do not buy it.
Now if you want real problems to complain about:
(1) bad A/C control
(2) wrong scale/offset used for setting up the stock map sensor.
Old Sep 21, 2010 | 05:12 PM
arghx's Avatar
rotorhead
Originally Posted by $lacker
Argh
Apex'i hasn't done any updating in a very long time unfortunately and I wouldn't expect anything any time soon (if ever).
Old Sep 21, 2010 | 07:25 PM
$lacker's Avatar
That seems a little harsh... do you never suggest improvements for anything?
I thought the FC-Edit software was produced by the Datalogit guys, not Apexi. Is that not right?
Old Sep 21, 2010 | 10:47 PM
cewrx7r1's Avatar
Eye In The Sky
"do you never" is double negative which is positive and also means I do which is the truth.
I am one of two who have given more than anyone else since 1999 on this forum and other forums.
You should know this as you joined my tuning group. I have done more for PFC/DL learning than most owners.
But I do not like lazy or whiner newbs.
_Tones_
May 25, 2021 05:37 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
The1Sun
Sep 7, 2015 10:21 PM
