what are symptoms of a bad transmission
Old Jun 28, 2002 | 09:26 PM
Hey guys I was kind of curious two what symptoms you may experience if there is something wrong with the transmission. I notice that when i step on the gas pedal especially in 1, 2, 3 gear i hear loud vibration coming from the rear of the car, sounds like grinding of some sort, any ideas of what it can be? when i shift i dont get any noise
Old Jun 28, 2002 | 09:36 PM
anybody know?
Old Jun 28, 2002 | 09:42 PM
Evan F D 3 S's Avatar
the rear? sounds like a differential problem...
Old Jun 28, 2002 | 10:54 PM
where are the fifferentials located in the rear? and how much is it to get fixed?
Old Jun 28, 2002 | 11:04 PM
diff location
the diff ia located in a rectange like box inbetween the middle of the wheels should be in middle of car
Old Jun 28, 2002 | 11:20 PM
FDokinawa's Avatar
Wait until you get a loud "thud" from your rear-end.. thats your diff shatering and shooting out the housing.. not a fun feeling.. you might want to get that looked at.
Old Jun 28, 2002 | 11:21 PM
P'cola FD's Avatar
Hamado things my way!
In the middle of the back of your car is the pumpkin that the axles go into. Drain the fluid from it, and see if there are chunks of metal in the fluid. If you want to upgrade the Kaaz is like 700-800 bucks. I'm not sure how much a stock one is though.
Old Jun 29, 2002 | 12:27 AM
anybody have a pic of this on our car here? the differential rectangular box?
Old Jun 29, 2002 | 12:31 AM
P'cola FD's Avatar
I don't have a picture, but if you align yourself with your liscence plate, get your head to the ground, and look to the front of the car, the differential will be right in front of you. Just look at where the axles lead to.
Old Jun 29, 2002 | 02:06 AM
Dont be A Rikki thanks so much for your help man, thanks for those pics aswell, now my question is could that be my problem from the noises I am describing above? if so how much is it to fix the rear differential?
alexdimen
20
Oct 23, 2015 01:50 PM
Monsterbox
Sep 11, 2015 03:29 PM
Enzo1944
Sep 6, 2015 08:57 AM
