Adjusting height, coil-overs, what am I doing wrong?
I've got some Stance coil-overs and I can't figure out how to adjust the height to raise my car up.
The manual calls for at least a inch and a half threaded on the lower mounting bracket or something might break, even with this my car was around 23 inches from the ground to the wheel arches on stock wheels.
It would seem that the thing everything is threaded onto would thread further down allowing more thread available for the lower bracket(I hope that makes sense) but all it does is spin in place.
The rears are the same but no where near as low.
What am I doing wrong?
Trending Topics
hand tighten isn't going to be enough. Do you have an instruction sheet? I know when I got my Teins there was instruction with them with a initial setting on where to set the spring perch.
Other forums say it should just be hand tightened.
I know this is asking the obvious. But, I'd check to make sure these are the right coilovers for our car. These don't need helper springs, do they? My understanding is like yours, the upper spring perch only affects pre-load and it's the lower locking ring that adjusts ride height. You already have the coilover separated (at the bottom) and that's where the ride height adjusts...
when I got my coilovers they sent me the wrong spring rate. Might want to give Stance a call
both perches will change your ride height. preloading the spring raises the car. the instructions just tell you not to mess with it because if you preload the rear too far, it can create some wonky handling issues. ("too far" being like 2" maybe). so yah if you actually need to raise the car another 2", and you're out of room on the bottom... maybe you do have a real issue to address.
can other stance owners comment on this? i know theyre designed to go low, but that does seem excessively low for how he has them setup.
toplessFC3Sman
Mar 20, 2018 01:54 PM
FD3S_wanted
Sep 22, 2015 06:18 PM
The1Sun
Sep 18, 2015 07:13 PM
