Car is jerky as hell
Old Sep 7, 2010 | 01:30 PM
1jzSC's Avatar
I own a S5 Turbo, just got it recently. I've noticed that to make the car drive smoothly, you need an EXTREMELY steady right foot, because any movement on the gas pedal will cause to car to jerk back and forth, especially in 1st and 2nd...I don't think this is normal, but I have no idea what the deal is behind it. Any help will be greatly appreciated!!
Old Sep 7, 2010 | 01:37 PM
satch's Avatar
If the car bucks during deceleration then check and adjust the TPS to 1 volt after the car is thoroughly warmed up.
Old Sep 7, 2010 | 01:56 PM
Trxncntlis4nubs's Avatar
Movin' on up...
could it not also be the differential to drivetrain mount being broken? seen that on a number of rx-7s before...and I'm assuming its not just a chattery transmission?
Old Sep 7, 2010 | 03:16 PM
3vil's Avatar
Mazda Misfit
TPS is easy to adjust, and therefore would be the logical place to start.
Old Sep 7, 2010 | 03:36 PM
Jet-Lee's Avatar
Unconventional
Front mount on the diff is another possible culprit. Is there a *clunk* from the rear end when you give it throttle?
Old Sep 7, 2010 | 03:44 PM
jjwalker's Avatar
MECP Certified Installer
My factory TPS was so off, you couldn't accurately adjust it. It was like throttle on or off, no in between. TPS replacement cured that issue entirely.
Actually, under extremely light throttle situations, you'll notice the engines runs on one rotor with a proper TPS.
cristoDathird
28
May 30, 2019 08:47 PM
autoxer
21
May 22, 2019 04:07 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
