Another starts and goes dead thread
Old Sep 5, 2010 | 05:50 PM
jdonnell's Avatar
Well I have this starts goes dead issue unless I quickly push the acelerator pedal. Once it races to ~3K rpm it wants to die unless I push the pedal in a couple times, then it seems to be ok. No sign of vacuum hose issue, MAF sensor connector tight and air hose to TB looks ok. ?????????????
90 Vert MTX
Old Sep 5, 2010 | 06:18 PM
rotary_bünta's Avatar
Rotary Retard
fuel pump?
Old Sep 6, 2010 | 07:17 AM
jdonnell's Avatar
Dont thin its the fuel pump. Replaced it a couple months ago w/filter in tank and inline filter. It was Mazda OEM.
Old Sep 6, 2010 | 08:59 AM
Go48's Avatar
What mods to the engine? Have you removed the AWS--the emission stuff? More info might help.
Old Sep 6, 2010 | 12:23 PM
jdonnell's Avatar
100% stock. I think I found the problem. The double throttle diaphgram on the front of the TB will not hold a vacuum when I try to test it using a vacuum pump. So I think the diaphragm is dead and the TB gates that open want to slam shut upon start up. Not 100% sure because if I hit the gas a few times it will not die.
streetlegal?
Mar 17, 2022 02:46 PM
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
85TIIDEVIL
Aug 25, 2015 12:09 AM
