13b turbo won't turn over by hand
Old Sep 4, 2010 | 09:41 PM
BurritoBut's Avatar
Just tried to turn it over by hand and it's fine to a point. It feels like it's got compression even with the plugs out and won't complete a turn. It only had the intake and exhaust manifolds bolted on.
Old Sep 4, 2010 | 09:48 PM
20Bforme's Avatar
three spinning triangles
fresh built motor i assume? new seals... old housings?
Old Sep 4, 2010 | 09:56 PM
rnz520's Avatar
No Pistons
What do you mean wont complete a turn, like it spins and then locks up at a certain spot?
Old Sep 4, 2010 | 11:31 PM
BurritoBut's Avatar
It's done a few ks and it's stock. It was running fine when I took it off the road. I took it off just to clean/paint/remove emissions etc.
It turns smoothly then gets hard to turn, just as if the spark plugs are in and it has compression. If I turn it as far as it goes and let go it springs back a little.
Old Sep 4, 2010 | 11:33 PM
BurritoBut's Avatar
It's not like it turns and hits something either it just turns freely then gets really tight.
Old Sep 5, 2010 | 08:32 AM
rnz520's Avatar
No Pistons
did you drop something down the intake manifold?
Old Sep 5, 2010 | 09:52 AM
20Bforme's Avatar
well... if you think about it... if you are turning the engine over by hand (as in the turning the crank pulley), with the plugs in the motor... it is gonna get hard to turn once it build compression.
Old Sep 5, 2010 | 10:18 AM
jjwalker's Avatar
MECP Certified Installer
Yeah, be glad, good compression is good.
My old motor was easy to turn by hand....I mean hand, not by wrench.
Old Sep 5, 2010 | 10:43 AM
arghx's Avatar
rotorhead
so are the plugs in or not?
Old Sep 5, 2010 | 11:07 AM
EnjoiPugs's Avatar
In the shade
After it "gets really tight" do you hear air chug out of the exhaust ports? Clarify a little more, will it actually turn all the way in circles or is it just hard to turn? You should hear one burst of air every time you turn it half way. It takes six "bursts" to complete a cycle I believe. Sorry if I am stating the obvious here.
Old Sep 6, 2010 | 12:26 AM
BurritoBut's Avatar
Im such a blonde sometimes....
Forgot it was in gear
Thanks for the help!
Old Sep 6, 2010 | 11:06 AM
20Bforme's Avatar
Old Sep 6, 2010 | 11:25 AM
2slow4stock's Avatar
The waiting game......
oh wow.
PhillyFC
Aug 21, 2015 06:36 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Machupicchu
Aug 17, 2015 08:27 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
