width of steering rack
Old Sep 4, 2010 | 01:58 AM
abtosway's Avatar
Two doritos, on a stick..
Hey guys! I have swapped a 91 rhd fc crossmember and front suspension into my 79 sa. I bought an 87 lhd steering rack from a member in order to put it in and get lhd.
now I have made my own mounts but the crossmember simply will not reach the female tie rod attachments on the wheels.
the driver's side the tie rod is 1 inch short and on the passenger side my tie rod is 4 inches short!!
I have meausred my steering rack to be 44 inches from the tip of one tie rod to the tip of the other and the gap is 49 inches.
Have I got the wrong rack?
How wide is an s4 and s5 steering rack?
thank you!
Chris
Old Sep 8, 2010 | 09:31 PM
misterstyx69's Avatar
Retired Moderator, RIP
wouldn't the RHD crossmember put the Steering box mount on the wrong side of the car?If you are making the Car an LHD?.
On the drivers side (LHD ) the mount has 4 bolts..on the passenger side it has 2.
..the only thing I can think of is everything is getting Reversed when you try to use RHD crossmember and the LHD rack.
NOTE:if you really need a measurement of a Power Rack(s4) AND a manual rack.,.I got TWO sitting outside.,and I can get the Measurements for ya,.PM ME if ya want them.
Old Sep 8, 2010 | 10:16 PM
959595rotor's Avatar
old dog
the power rack, I have measured 22 inches long, the outer tie rod to tie rod length is 54 inches,it was removed from a running car if you can't make it work,or need a left hand cross member ,etc, or Help call me at 1 - 204 275 1589 ps I have done this swap a few times ,.good luck
Old Sep 9, 2010 | 09:31 PM
abtosway's Avatar
Thanks for your help! I just picked up a used actual FC power rack from RX7 Specialties here. Looks to have the right dimension, what a load off haha.
Looks like the other rack sold to us by a member here as an FC rack is in fact a Miata unit. This is certainly disappointing, but everyone's assistance makes up for that.
