blitz sbc i-color boost controller
Old Aug 31, 2010 | 07:30 PM
Beansy's Avatar
UT blitz sbc i-color boost controller
I just got this unit from a buddy of mine.... My car is a 88 tii completely stock... i was wondering if it is worth my time to install this or should i just leave it be... any advice will be greatly appreciated
Old Aug 31, 2010 | 11:40 PM
arghx's Avatar
rotorhead
When you open up the exhaust a little it will raise the boost anyway. Go slowly with the modifications, don't just put a boost controller on there. It's a quick way to blow up your engine. Try starting with a catback exhaust and then do some more research on modifying a T2 engine.
I'm pretty surprised to hear that you have a completely stock T2 actually. Is it nice? Got any pics?
Old Sep 1, 2010 | 12:30 AM
Beansy's Avatar
I bought a year ago and it had 31k original miles on it... I have posted some pics on here
Old Sep 1, 2010 | 07:27 AM
durtled's Avatar
"this album doesn't have any pictures" where did u post them?
Old Sep 1, 2010 | 07:55 AM
arghx's Avatar
rotorhead
start with a catback or downpipe maybe... don't pull the factory cat off right now because that will cause overboosting problems without pulling the turbo and porting the wastegate, which will be a pretty big job
Old Sep 1, 2010 | 12:00 PM
Beansy's Avatar
here is a pic
Old Sep 1, 2010 | 12:09 PM
Beansy's Avatar
I want to get a RB catback but it's expensive.... I will have to look for a cheaper alternative.... If i get a down pipe wouldn't it cause boost creep also?
Old Sep 1, 2010 | 06:26 PM
arghx's Avatar
rotorhead
look for a used RB catback. what really gets you is the shipping.
I'm not 100% sure what your boost will be if you just swapped out the downpipe and left everything else stock. There aren't too many stock T2's out there running properly so it's hard to get input from people. Like most owners, my car was already modified when I bought it. What I can tell you though is that just swapping to a downpipe will be safer than installing a boost controller and presumably a fuel cut defender on top of that. Less can go wrong. Worst case scenario is that your boost rises 1-2psi and you might hit overboost fuel cut if the weather gets really cold.
With an EBC you'll either hit fuel cut immediately, which won't make the car very fun to drive, or you will have to eliminate the fuel cut with a fuel cut defender box or a chipped ECU. And then you will have to start checking your AFR's etc.
You know what would be really cool? If you bought a wideband, installed the sensors after the precats, and took a video showing AFR's on a completely stock car. You'll probably want a wideband eventually if you plan to mod it. It would be interesting to see if the AFR's change much as you start installing aftermarket intake or exhaust stuff.
