where is a good interior 12v switched source?
Old Aug 31, 2010 | 08:54 AM
Dltreezan's Avatar
My Bick is Digger
I need a good source of switched power, preferrably near the passenger footwell area that is switched AND WONT DIE when cranking the car. Thanks!
Old Aug 31, 2010 | 09:10 AM
satch's Avatar
Black/Yellow wire to the blower motor.
Old Aug 31, 2010 | 09:12 AM
Go48's Avatar
Cigarette lighter power wire.
Old Aug 31, 2010 | 09:19 AM
satch's Avatar
That particular wire feeds off of an accessory fuse which loses power temporarily when the key is turned to start, thus he needs to tap into a wire which is powered by one of the IG1 fuses.
Old Aug 31, 2010 | 01:32 PM
Dltreezan's Avatar
My Bick is Digger
awesome. Thanks satch....
Old Aug 31, 2010 | 05:13 PM
Dltreezan's Avatar
My Bick is Digger
ok my blower motor only had a white and blue and a ground and that didnt work...
Old Aug 31, 2010 | 05:17 PM
satch's Avatar
Sorry about that for I used an S4 wiring diagram not realizing your's is an S5. So the non ground wire doesn't have voltage w/key to on? I'll take a look at the S5 diagram but it takes a while to fully download unlike the S4 version.
EDIT: If your car is wired for power windows then the Black/Red would work.
Old Aug 31, 2010 | 06:21 PM
satch's Avatar
Image below shows where connector G-10 is to be found. This connector mates two plugs. The front side of the harness has the following wires; R/Y, L, B, G/R, B/R, B/Y, L/O, L/Y and the other side of the connector has; L/W, B, L, R/Y, L/Y, L/O, Y, Y/L. B/Y in the front harness will work and this wire mates up with Yellow on the other side of the connector.
Old Aug 31, 2010 | 06:41 PM
Hypertek's Avatar
Slowpoke
stereo
Old Aug 31, 2010 | 07:12 PM
satch's Avatar
Originally Posted by Hypertek
stereo
He wants "switched power that doesn't shut off briefly when the key is put to start."
Old Sep 1, 2010 | 01:35 AM
john ward's Avatar
oi oi oi
ignition barrel
Old Sep 1, 2010 | 02:38 PM
1990_fC3C_t2's Avatar
Idiot
So it's a bad thing ive got my wideband heater wire connected through the cigarette lighter? Should i change it to one of the others listed?
Old Sep 1, 2010 | 02:46 PM
satch's Avatar
Being run off the ACC fuses the only difference between those and the IG1 fuses are that when you turn the key to start the ACC fuses lose power but only for a very short period of time. I'm not familiar with what a wideband heater is but all you need to ask yourself is if it's fine for it to lose power for the briefest of moments when the key is turned to start then you are okay.
LunchboxSA22
37
Oct 26, 2015 10:53 AM
